fuel pump? - JeepForum.com
post #1 of 9 Old 06-03-2010, 09:29 AM Thread Starter
Spigger73
1987 YJ Wrangler
fuel pump?
Ok so i was wondering what did for the fuel pump when u did your 4.0 swap?.....i have an 87 but i cant seem to find a whole sending unit that comes with a 6cyl fuel pump that fits my gas tank any suggestions? TIA
87 YJ{94 4.0}5 spd{ax-15} 4.5 RE lift1 1/4 HD shackels
36 Super swamper iroks
Spigger73 is offline
post #2 of 9 Old 06-03-2010, 09:45 AM
Que89YJ
Do the poly tank swap with any post 91 yj. The fuel pumps are the same for the 2.5 and the 4.0. You can find the tanks and pumps for usually under $100 dollars and its a bolt in.
Que89YJ is online now
post #3 of 9 Old 06-03-2010, 09:47 AM
Que89YJ
Dont forget the fuel lines if you are going from the 4.2L to the 4.0L
post #4 of 9 Old 06-03-2010, 10:04 AM Thread Starter
Spigger73
1987 YJ Wrangler
i went from a 2.5L to a 4.0L. So i guess i dont need to worry about the lines but i guess i need a new gas tank
post #5 of 9 Old 06-03-2010, 10:15 AM
Que89YJ
Its just easier and cheaper plus you get the added 5 gallons too.
post #6 of 9 Old 06-03-2010, 01:28 PM Thread Starter
Spigger73
1987 YJ Wrangler
where would i find one of these tanks junkyards? or online as a whole Assembly
post #7 of 9 Old 06-03-2010, 01:53 PM
remmons
I went with the 91-95 stock fuel pump/sender unit. It keeps the installation clean and simple. I went to a salvage yard and asked if they could put out a call on their parts locator network.
After I received my packages, I took note of one of the suppliers labels. The fuel pump/sender unit assy. came from Brock Supply
Here is a pic that I took for the sending unit comparisons. You can see one of the shipping box labels/tape with the info. You might try here.
Of course it requires the use of the 20 gallon Poly tank, (if you don't have one already) but this is a great upgrade while you're under there. It is a good idea to replace the fuel lines with high pressure fuel injection hose, it is available at any reputable parts store.
Robert.
remmons is offline
post #8 of 9 Old 06-03-2010, 02:03 PM
Que89YJ
Car-part.com or craigslist. No problem finding a whole used one from someone parting out a YJ
post #9 of 9 Old 06-10-2010, 10:28 AM Thread Starter
Spigger73
1987 YJ Wrangler
thank you im on the search for it right now!
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 04:42 PM
inline fuel pump or new tank with pump in it? cubbybear YJ Wrangler Technical Forum 2 12-25-2008 05:13 PM
Fuel pump assembly vs. fuel pump? eclipse27 TJ Wrangler Technical Forum 11 11-11-2008 09:18 AM
Electric Fuel Pump Issue, NOT pump 1995yj1978cj YJ Wrangler Technical Forum 4 05-28-2005 12:12 PM
