Fuel Pressure at rest - JeepForum.com
post #1 of 3 Old 03-03-2013, 07:33 PM Thread Starter
idskot
Hey, all. In early January (2 months, let's say) my axle strap in the rear busted. In lieu of adding a band-aid, I decided to swap in an 8.8. That took time. Today I got the mounting hardware welded on.
My main question is this: prior to January, my Jeep would start instantly. After it sat for about a month with out starting, it took a few seconds to turn over. After that, every week when I'd start it, I had to prime the fuel pump a few times (Turn the key on, then off, then back on so the fuel pump builds up pressure).
Today, I drove it to my friend's house to get welded, in the 5 hours it took for us to quit our BS and actually work, it lost fuel pressure again and I had to crank it for a few seconds for it to start.
Any ideas? Bad fuel pressure regulator?
idskot is offline
post #2 of 3 Old 03-04-2013, 09:30 AM Thread Starter
idskot
Bump?
idskot is offline
post #3 of 3 Old 03-04-2013, 01:03 PM
Que89YJ
Bleed down fuel pressure test and see if it stays above 20psi after 20 minutes.
Que89YJ is offline
