Fuel Pressure Regulator - Do we have one?! - JeepForum.com
post #1 of 13 Old 12-11-2010, 10:19 AM Thread Starter
bawlnchayn
1990 YJ 4.2L I6 Carburetor
We seem to be having some fuel issues - I can't find the answer in our Hayne's manual... (going out to get the YJ Specific manual from Chilton's )
Do we have a fuel pressure regulator?
And, where is it, if we do?
Thanks!!
bawlnchayn is offline
post #2 of 13 Old 12-11-2010, 10:23 AM
Mywrangler94
are you sure that your float isn't stuck? Would try to check that first....
Mywrangler94 is offline
post #3 of 13 Old 12-11-2010, 10:38 AM Thread Starter
bawlnchayn
Well, the fuel problem isn't an all the time thing. It's only when the tank gets to about 1/4 full - the truck will run fine, idle smooth, but when at a stop, it wants to die out (and will if we don't keep it revved up) and when the accelerator is pressed it dies. Then, it's able to be started right back up again. We also lost about 8mpg during this last full tank (which is about half of what we were getting, so we're losing a lot of gas). When the tank is full, it runs great - starts up great in the cold mornings, idles and accelerates fine.
There's no smoke, oil loss, ... We replaced the fuel filter about 5 months ago, but were thinking maybe we should replace the pump and filter, and regulator if we have one (the manual doesn't say).
post #4 of 13 Old 12-11-2010, 12:35 PM
91BoD
Wasn't the 90s a TBI set up?
If so, yes you have a regulator.
91BoD is offline
post #5 of 13 Old 12-11-2010, 06:08 PM
shagsjeep
If it is a manual pump that will be located on the pass side of the bock. If so it sounds like the pump is going out. It is a super simple easy fix then. New pump. When you replace the filter did you replace it with the correct filter?? If your's is like mine it has a return line off the filter so it a one inlit and a two outlit filter. If it's TBI I know nothing about them and I'm talking out my butt if I say anything :}
1989 Jeep wrangler YJ. 4.2L 258 in-line6, front dana 30 rear dana 35?? NP231 nothing fancy yet.
shagsjeep is offline
post #6 of 13 Old 12-14-2010, 10:11 AM Thread Starter
bawlnchayn
Yeah, you're right, it's not TBI. I'm no expert, but it has a carburetor and those two don't go hand in hand?
We did replace the fuel pump, the new fuel filter we put on a few months ago was still good so we didn't replace it. We put a new fuel line from the new pump and it's not kinked. (and you're right, it is on the pass side of the block). It ran fine for a day, now it's screwing up again! Now we have a HORRIBLE smell, it won't idle, chugs, white smoke, (oil and antifreeze look fine, but oil smells smokey), and is now sitting in the garage waiting for a bullet.
So, I don't think the pump was the problem. :
post #7 of 13 Old 12-14-2010, 11:41 AM
vadslram
My stock filter has the regulator/bypass built into it. 1 inlet on one side of the can and two outlets on the other. The one on the edge should be positioned on top to help remove air and it's connected to the tank return line.
vadslram is offline
post #8 of 13 Old 12-14-2010, 11:52 AM
muddy93
1987 FSJ Wagoneer
quote: "Well, the fuel problem isn't an all the time thing. It's only when the tank gets to about 1/4 full - ":quote
This kind of makes me wander if it's a problem with the pickup tube in the tank?
I've never experienced it myself, but I've heard of several people that had rust holes in the pickup tube. when the fuel would get below the holes in the tube, air would be drawn into the fuel line and cause issues.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #9 of 13 Old 12-14-2010, 02:13 PM
superj
mine does the issues below a quarter also but mine only read "right" from a quarter down. at that point i know its almost out of gas so maybe your sending unit was reading wrong and you were actually almost out of gas? thats teh symptoms on mine and i know its almost out of gas at that point.
also, what carb do you have?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #10 of 13 Old 12-14-2010, 07:48 PM
dodger889
Check your draw tube in your fuel tank.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #11 of 13 Old 12-15-2010, 09:33 AM Thread Starter
bawlnchayn
I'm pretty sure, from what others have said according to pics I posted, that we have the stock carter bbd carb (not sure if I'm saying that right - wife posting haha).
Anyways, we replaced the pump and it ran fine, it seemed , for a day, then yesterday it pooped out. We took apart the carb and where the two streams of gas squirt into the carb, one of the brass looking jets is missing and puking gas into the carb - the other one is intact and squirts fine.
/sarcasm
We're looking at replacing the carb - we have to find the little brass looking jet piece tho. We're PRETTY sure that since both sides of the inside of the carb are the same that we should have 2 of those jet tubes intact. ?
post #12 of 13 Old 12-15-2010, 10:10 AM
vadslram
Pieces missing from carb = VERY BAD
I would pull the intake manifold just because.
The brass piece may be on the ground somewhere or stuck in the heat exchanger on the manifold or even gotten all the way through and somewhere in you exhaust system...but it could also be just waiting to drive a hole in a piston or mess up a valve.
vadslram is offline
post #13 of 13 Old 12-15-2010, 11:16 AM Thread Starter
bawlnchayn
Yup, that's pretty much our train of thought, too. We were VERY surprised to see that last night - last thing we would have guessed!
Got the rental so the Jeep isn't going anywhere or doing anything until we find that piece. Hopefully, as we piece it apart, night by night, and all day Sat/Sun we'll find it. LOL It's so messed up it's almost funny.
Fuel pressure regulator help. treefiddyYJ YJ Wrangler Technical Forum 12 06-01-2009 10:26 PM
Fuel Pressure Regulator bigdogcp YJ Wrangler Technical Forum 6 06-01-2009 11:06 AM
fuel pressure regulator mibble98 TJ Wrangler Technical Forum 0 03-15-2007 07:00 AM
Fuel Pressure Regulator Jeepfan Jeff YJ Wrangler Technical Forum 1 04-23-2005 08:15 AM
Fuel Pressure Regulator JEEPIN_I_AM YJ Wrangler Technical Forum 1 07-07-2002 01:58 PM
