fuel pressure regulator - JeepForum.com
post #1 of 4 Old 06-08-2003, 03:55 PM Thread Starter
mv971
Has anybody used a fuel pressure regulator with a weber carb i am thinking of getting one just want some feedback if its worth it or not .?does it increase mpg ?does it help in tuning the wber thanks mike
mv971 is offline
post #2 of 4 Old 06-08-2003, 06:05 PM
Meister_jeep
Well you don't really need them 100% of the time with a weber. It is just some people like me needed them to get the Weber to run better. Try it without the regulator and adjust the carb at the exact point that it is tuned correctly. If you get worst MPG then you could try a Fuel pressure regulator.
1988 YJ 4.2l
__________________________________________________ __
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
FORD 8.8 WITH 4.10 GEARS, DISK BRAKES
33x12.50 GOODYEAR MT/R's ON AR767 15x8
CUSTOM STANLESS STEEL DISCO`s
JUICEBOX.
LED TAIL LIGHTS
$10 homemade POSILOCK
(IN THE WORKS THIS SUMMER)
-Custom front and rear bumpers
-HEI UPGRADE
-4.0 HEAD
-MIGHT TRY THE JEEP INJECTION KIT FROM WEBER
Meister_jeep is offline
post #3 of 4 Old 07-02-2003, 09:38 AM Thread Starter
mv971
DONT BUY A NAPA ONE
I HAD IT ONE FOR TWO WEEKS AND IT STARTED LEAKING BAD IT DIDNT RUN MUCH BETTER EITHER
mv971 is offline
post #4 of 4 Old 07-02-2003, 01:57 PM
KEVNISE
I use one on my weber works fine and getting 17mpg with 31"s
90 wrangler weber carb nutter bypass 4" lift pro comp 4.2 liter 33" muds 411 gears
69 camaro
KEVNISE is offline
Fuel Pressure Regulator veritas4156 YJ Wrangler Technical Forum 11 03-07-2010 03:26 PM
fuel pressure regulator 2.5l Bryan01702 YJ Wrangler Technical Forum 8 01-26-2010 10:08 PM
Fuel pressure regulator help. treefiddyYJ YJ Wrangler Technical Forum 12 06-01-2009 10:26 PM
Fuel Pressure Regulator Jeepfan Jeff YJ Wrangler Technical Forum 1 04-23-2005 08:15 AM
Fuel Pressure Regulator tclark YJ Wrangler Technical Forum 10 04-12-2005 02:16 PM
