fuel pressure regulator 2.5l - JeepForum.com
post #1 of 9 Old 01-26-2010, 05:37 PM Thread Starter
Bryan01702
where is this located. have a book and still can't figure out. im searchin to see if that vacuum line is hooked up.
Bryan01702 is offline
post #2 of 9 Old 01-26-2010, 06:00 PM
kloppk
Profile, profile, profile....
Give us a clue what vehicle you are asking about
kloppk is offline
post #3 of 9 Old 01-26-2010, 07:53 PM Thread Starter
Bryan01702
2.5l haha sorry that information might be helpful.
post #4 of 9 Old 01-26-2010, 07:59 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
What year 2.5?
5.7YJ is offline
post #5 of 9 Old 01-26-2010, 07:59 PM
ritjobbie
On my EFI 1995's 2.5L, the fuel pressure regulator is on the front of the fuel rail (closest the headlights). It's right next to where the two fuel lines connect to the front of the fuel rail. Driver's side of the engine.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #6 of 9 Old 01-26-2010, 08:02 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Throttle body(TBI) models have the fuel pressure regulator on the throttle body.
5.7YJ is offline
post #7 of 9 Old 01-26-2010, 10:49 PM Thread Starter
Bryan01702
do you know where that vacuum line goes? there should be one on it correct?
post #8 of 9 Old 01-26-2010, 10:51 PM Thread Starter
Bryan01702
and its TBI
post #9 of 9 Old 01-26-2010, 11:08 PM
J33Pyj
your regulator is on the TB it is on the passanger back side of the TB. You have to unbolt and flip the TB upside down to remove it.
90 yj/ 4:88 gears/33x12.50x15 Super Swamper TRXUS Mud Terrains/K&N air system/2.5L/D30front aussie equip'd/D35 rear / 3in BL/ 2in shackle lift / XRC8 Winch
If you havent broken it, you havent been wheelin
J33Pyj is offline
Fuel Pressure Regulator mattcm88 TJ Wrangler Technical Forum 1 07-18-2009 08:36 PM
Fuel Pressure Regulator bigdogcp YJ Wrangler Technical Forum 6 06-01-2009 12:06 PM
fuel pressure regulator Sfrid073 TJ Wrangler Technical Forum 2 07-22-2005 10:50 PM
Fuel Pressure Regulator Jeepfan Jeff YJ Wrangler Technical Forum 1 04-23-2005 09:15 AM
Fuel Pressure Regulator JEEPIN_I_AM YJ Wrangler Technical Forum 1 07-07-2002 02:58 PM
