fuel pressure regulator - JeepForum.com
post #1 of 7 Old 03-22-2012, 05:06 PM Thread Starter
marvinb
Anyone who has done a V8 swap in there YJ and is running a carb.. How are you delivering fuel? Im running a stock manual fuel pump on my 305 and am pulling fuel thru my electric fuel pump which is causing a fuel starve issue..
If anyone is running there stock electric fuel pump, and a big honkin fuel pressure regulator, what regulator are you guys using? Part#?
Ive searched for several days now and i cant find a particular thread where anyone has given a part # or a particular brand.. but i have seen where people suggest a big ol honkin regulator..
any help would be appreciated
1991 jeep wrangler.SOA. Chevy 305/ 700R4 tranny/ NP231C/J Transfer case, B&M Z gate shifter, Autometer gauges. Mickey Thompson Classic Lock 2s/ 33x12.5x15 federal couragia's. Bushwacker flares.
marvinb is offline
post #2 of 7 Old 03-22-2012, 08:42 PM
superj
use the holley regulator. sorry, i don;t have the number off hand but just go to the autoparts place and tell them you want the holley regulator with two outlets that is chrome and adjusts from 2-8psi. or use the stock 4.2 fuel filter that has two outlets and let the excess fuel run back to the tank. that is how mine is set up right now. i bought the holley electric fuel pump and mounted it on the fender and then was going to run it to the regulator but found out i had a return line so put a tee with the excess pressure bleeding back in to the tank. i still have the regulator and its like 30 bucks from oreily's.
and not to mislead you, i don;t have a v8
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 7 Old 03-22-2012, 08:43 PM
superj
http://www.livernoismotorsports.com/...Universal.html
here you go
superj is offline
post #4 of 7 Old 03-22-2012, 09:19 PM
4.7stroker
I am using a intank pump with a return style filter without a regulator. The return style filter stops you from blowing the needle off of the seat and the electric pump works great with my carb.
Just say NO to FPR's
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #5 of 7 Old 03-22-2012, 10:54 PM
superj
i agree
superj is offline
post #6 of 7 Old 03-23-2012, 01:15 PM
wendell
1987 YJ Wrangler
I just ordered a holley fuel reg from summit for my holley 4 barrel on my 258.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #7 of 7 Old 03-24-2012, 07:27 AM Thread Starter
marvinb
Update:
Did a little work to the jeep yesterday, installed a clear bowl fuel filter and a inline fuel pressure gauge up close to the carb. I also swapped fuel lines. Lemme explain fuel lines. On another thread a gentleman suggested using the
Return line as my primary fuel line to see if unrestricted flow would cure my "cutting out" issue. Well, it did!! The jeep has yet to "cut out" on me at all. Now I know that using the return line may not be the best fix, but it's working quite well so far. The gentleman who suggested the return line said that line should go all the way to the bottom of the tank. He was right. After some searching on the Internet for fuel sending units to see how they were made I came across one that was shown in an exploded view with the gas tank and in the bottom of said tank there was a small three sided raised area where the return line set into with what is called a stopper. So, return line swap was on.
So, here's where I'm at.
Had a fuel starving issue- fixed as of now
Had some nasty spark plugs-installed new Bosch platinum 4's
Running hot issue- swapped in a new 180* thermostat and a new electric fan
Thanks for info from everyone who replied to this thread or others I've started about this issue.
marvinb is offline
Fuel Pressure Regulator arveetek TJ Wrangler Technical Forum 0 01-02-2012 09:37 PM
do I need a fuel pressure regulator? 87YJerryRig YJ Wrangler Technical Forum 2 09-20-2011 04:48 PM
Fuel pressure regulator 89islandclunker YJ Wrangler Technical Forum 0 01-30-2011 01:08 PM
Fuel pressure regulator? jerresredyj YJ Wrangler Technical Forum 12 12-28-2010 08:05 AM
Fuel pressure regulator help. treefiddyYJ YJ Wrangler Technical Forum 12 06-01-2009 11:26 PM
