Fuel pressure regulator - JeepForum.com
post #1 of 11 Old 04-20-2010, 08:27 PM Thread Starter
95YJI6
do inline 6 yjs have a fuel pressure regulator? if so where would it be?
95 Wrangler YJ
15x8 Mickey Thompson Classic II Rims, 31 x 10.5 x 15 BFGoodrich All Terrain KOs, Hard Top / Soft Top. Teal Blue
95YJI6 is offline
post #2 of 11 Old 04-20-2010, 09:32 PM Thread Starter
95YJI6
also if there is one, can it be adjusted?
95 Wrangler YJ
95YJI6 is offline
post #3 of 11 Old 04-20-2010, 09:45 PM
hondacr21
hondacr21's Avatar
someone can correct me if I am wrong but where your fuel line connects to the fuel rail, the regulator is the little round thing with the vac line goin to it, then shortly after that there is the return line goin back to the tank. I dont believe it is adjustable
1995 Sahara, Borla header, Rear stretch 103" wheelbase, Sniper Fab Comp Corners with 3" flare, SOA with .75" SL, 2 1/2" Rancho lift on 37"s MTR's on 15x8 eagle alloys. JB4x4 steering bracket, M.O.R.E., 8.8 with limited slip and 4.10's, AA SYE, modified XJ front driveshaft, Superwinch EPi 9.0, homemade boatsides, 6 point cage.
hondacr21 is offline
post #4 of 11 Old 04-21-2010, 05:07 AM
Alfons
The regulator is on the fuel rail as you say, but it's part of the fuel return line instead of the feed & the stock regulator is not adjustable. If the fuel pressure drops, it's generally a big drop and is a result of pump problems - I rarely see regulator problems. If you're running rich, the vacuum line to the regulator could be disconnected -this would give you approximately 8lb. pressure increase.
What I would recommend getting a fuel pressure gauge and check all the pressures (normal, max, without vacuum, leak-down time).
Alfons is offline
post #5 of 11 Old 04-21-2010, 06:14 AM Thread Starter
95YJI6
what i am thinking is im running too lean and the car keeps stalling out
95 Wrangler YJ
95YJI6 is offline
post #6 of 11 Old 04-21-2010, 03:25 PM
Alfons
By checking the fuel pressures you can determine if you're on the right track or whether you have some sensor problem - if your fuel pressure is poor, you may need to look for a new pump. Have you tried to look for any stored diagnostic codes? There may not be any, but that still wouldn't mean that there wasn't a sensor problem, OBD1 had a lot of holes in it, but if you do have some codes, it would be a bonus in determining what your problem might be.
Alfons is offline
post #7 of 11 Old 04-21-2010, 05:14 PM Thread Starter
95YJI6
check engine light never came on, where is the obd1 port, i looked every where under the dash and found nothing!!! i know what it looks like is it on the passenger side maybe?
95 Wrangler YJ
95YJI6 is offline
post #8 of 11 Old 04-23-2010, 05:58 AM
Alfons
The OBD1 port is under the hood on the firewall, driver's side, close to where the clutch master is attached.
The CEL doesn't come on for every code. You can get the codes by using the key on-off-on-off-on method and counting the flashes of the CEL. There's a short break between the 2 digit numbers and a longer break between the numbers & keep in mind that the codes will ALL be 2 digit numbers.
You might consider getting a manual that describes the fuel system tests or do a search on this site for a description of these tests - I've posted some a few times. If you don't find anything, maybe I can find what I had previously posted.
Alfons is offline
post #9 of 11 Old 04-23-2010, 06:43 AM Thread Starter
95YJI6
ok, thanks i never thought of looking under the hood for it, i have an obd2 scanner now i just need to find someone who has an obd1
95 Wrangler YJ
95YJI6 is offline
post #10 of 11 Old 04-23-2010, 07:51 AM
Que89YJ
Look in the FAQ. You can check the faults without a scanner, but like he said, many of the sensors fail without throwing a fault code. Check your fault codes, check your fuel pressure. Post exactly what the symptoms are are what you find and I am sure someone can help here.
Que89YJ is offline
post #11 of 11 Old 04-23-2010, 08:28 AM
MJMPC
Here ya go read this.
OBDI Error/Check Engine Codes - JeepForum.com Community Jeep Wiki
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
Fuel Pressure Regulator mattcm88 TJ Wrangler Technical Forum 1 07-18-2009 07:36 PM
Fuel pressure regulator help. treefiddyYJ YJ Wrangler Technical Forum 12 06-01-2009 10:26 PM
fuel pressure regulator mibble98 TJ Wrangler Technical Forum 0 03-15-2007 07:00 AM
fuel pressure regulator Sfrid073 TJ Wrangler Technical Forum 2 07-22-2005 09:50 PM
fuel pressure regulator mv971 YJ Wrangler Technical Forum 3 07-02-2003 01:57 PM
