Fuel Pressure issues - JeepForum.com
post #1 of 7 Old 09-04-2011, 12:13 PM Thread Starter
duster70440
I have a 1989 YJ with a 2.5L engine. I've been having problems with the jeep not wanting to start or having to cycle the key to get the engine to start. I replaced the ECU (computer) and both relays in the engine bay then I purchases a GP Sorensen throttle body regulator rebuild kit from Autozone. After installing the new regulator diaphram and injector o-rings, I attempted to start the Jeep. It wouldn't start unless I put fuel into the throttle body directly by hand. I hooked up a fuel pressure gauge and found the fuel pump doesn't turn on every time I turn on the key. When it does come on the fuel pressure goes up to about 16lbs then falls to zero instantly. If I put fuel into the throttle body it starts and runs fine and the fuel pressure stays at 16lbs. even when I free flow the pump using my snap on fuel gauge. It has a bypass button on the gauge. HELP please. Im thinking it is the fuel pume itself causing the problem. I replace the fuel pump a few years ago with one from NAPA and they have sence switched suppliers so im not sure if they will replace it, was a life time warranty pump. Anyway this is whats going on can someone help me with some suggestions. Bob
duster70440 is offline
post #2 of 7 Old 09-04-2011, 01:56 PM
cstone94
I think I'm having the same problem. If I ride around and let the motor get to running temp (210) and shut it off, and try to start it after about 10 minutes, it just winds the starter. Then after about 20 minutes, it will slowly start to get ready to start and the it will start climbing from 100 RPM up until the choke kicks on. Does yours have any of the same problems as mine?
cstone94 is offline
post #3 of 7 Old 09-04-2011, 07:41 PM
brentd711
My '90 2.5L TBI decided it didn't want to start when cold without a splash of fuel dumped in the throttle body. It would run all day long and restart OK if the temp didn't drop below about 190. I disconnected the wide-open throttle switch (a microswitch on the throttle cable bracket) and it has started fine ever since.
Here's my thread trying to diagnose the problem
yj-no-start-w-o-priming
brentd711 is offline
post #4 of 7 Old 09-05-2011, 06:41 AM
nembudonna
That WTO switch seems stupid to me. I took mine off also. I know how it works but why have it?
nembudonna is offline
post #5 of 7 Old 09-05-2011, 09:49 AM Thread Starter
duster70440
Sorry cstone, but mine doesnt do any of that. I can put gas into the throttle body and it will start then when its at normal operating temp. it will start half the time. Im going to try unpluging the WOT switch and see what happens. I will let you all know. thanks Bob
post #6 of 7 Old 09-05-2011, 10:04 AM
brentd711
I want to see the 440 Duster
post #7 of 7 Old 09-06-2011, 05:25 PM Thread Starter
duster70440
I will see about posting pics of my duster for you to see soon
fuel , no start , regulator
Gas Tank PRESSURE??? Or Fuel RELIEF PRESSURE?? 915kingwrangler YJ Wrangler Technical Forum 22 03-21-2016 05:33 PM
Fuel pump/fuel pressure testing kbfunTH YJ Wrangler Technical Forum 2 03-24-2011 12:07 PM
How do you release the fuel pressure at the fuel rail on a 2005 4.0? msully TJ Wrangler Technical Forum 7 11-14-2010 12:11 PM
Fuel pressure too high - Fuel return line problems ChiroSean YJ Wrangler Technical Forum 4 08-11-2009 09:57 AM
1990 4.2 weber fuel pressure issues tippmann243 YJ Wrangler Technical Forum 7 05-23-2009 06:07 PM
