Fuel Pressure - JeepForum.com
post #1 of 4 Old 11-25-2011, 03:38 PM Thread Starter
TA-YJ
Fuel Pressure
Real simple question. I need to know what the fuel pressure should be for a 92 2.5 MPI engine. Ive searched, but have seen conflicting results from anywhere from 15psi to 45psi. I thought it was 31psi at idle, but I am not sure now. I am at 34psi so I just needed conformation. Thanks.
1992 YJ 2.5L
Engine Mods:4.0L TB, Ford Design III 19lb Injectors, Firepower Ignition System, Ford TBird Electric Fan, Pacesetter Header, Magnaflow Cat, Dynomax Super Turbo Exhaust
Suspension Mods:BDS 2" Lift, M.O.R.E. 5/8" HD Shackles, 1" Brown Dog MML
Other:LED Tails and Herculined
TA-YJ is offline
post #2 of 4 Old 11-25-2011, 03:54 PM
moonshinefuel
30 is about right, it can go up if you remove a certain line on the fuel rail.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 4 Old 11-25-2011, 04:13 PM
oldtime_ironman
31 PSI at idle, it may go up to 39 PSI if you unplug the vacuum line from the regulator.
oldtime_ironman is offline
post #4 of 4 Old 11-25-2011, 04:19 PM Thread Starter
TA-YJ
Im at 34psi with all lines connected, so I think Im good. From what I have read its better to have a little higher psi with the ford injectors anyway. Thanks for the quick response.
1992 YJ 2.5L
TA-YJ is offline
Gas Tank PRESSURE??? Or Fuel RELIEF PRESSURE?? 915kingwrangler YJ Wrangler Technical Forum 22 03-21-2016 06:33 PM
How do you release the fuel pressure at the fuel rail on a 2005 4.0? msully TJ Wrangler Technical Forum 7 11-14-2010 01:11 PM
How to test fuel pump/fuel pressure on '05 4.0L Zen TJ Wrangler Technical Forum 18 05-12-2010 09:34 AM
Fuel pressure too high - Fuel return line problems ChiroSean YJ Wrangler Technical Forum 4 08-11-2009 10:57 AM
High fuel pressure at the fuel rail ChiroSean YJ Wrangler Technical Forum 5 12-17-2008 02:02 PM
