fuel lines question - JeepForum.com
post #1 of 4 Old 01-08-2012, 05:56 PM Thread Starter
JUNKYARDDOG01
fuel lines question
i dropped my tank today to replace the fuel hoses from the fuel pump to the car. i ran into an issue where i couldnt remove the lines because they were routed in between the chassis and body. someone suggested i loosen the bolts to the body and jack it up.. well i did and it worked.
i routed the lines back through without the foam padding. put everything together and the car started but shuts off within seconds....
do you guys think i pinched a hose routing it through the chasis again or other issues. i hear the pump kick on? i did not disconnect the battery, my mistake but i dont think i blew a fuse??
any suggestions would be appreciated. i prob have to drop the tank again to check the lines aren kinked huh??
JUNKYARDDOG01 is offline
post #2 of 4 Old 01-08-2012, 08:34 PM
MJDriver
MJDriver's Avatar
Double check that you didn't kink the line from the pump to the crossmember space and over to the hard lines, when you put the tank back in. I duct taped mine into the space relieved into the top of the tank. I also removed the rubber block that the lines ran through (yours is foam) in the cross member. The space was so tight I had to coat the lines in vaseline to get them to squish through. Also, give enough slack to make the bends easy and no sharp angles.
Good luck.
Current - 1993 Wrangler 2.5 - mostly stock
Previous - 1989 Comanche Pioneer 4x4 Long Bed/Metric Ton Pkg
4.0, AT, D44 w/ Trak-Lok RIP
MJDriver is offline
post #3 of 4 Old 01-09-2012, 06:41 AM
nembudonna
You have to drop the tank. It sounds like you pinched the fuel line somewhere.
nembudonna is offline
post #4 of 4 Old 01-09-2012, 09:16 AM Thread Starter
JUNKYARDDOG01
i think so..dropping it tonight ahrrg. at least i can say ive done 3x!!! lol thanks for the info..by the way you guys dont think, the lines are pinched in between the chassis do you??
rubber fuel lines between pump and hard lines pointech YJ Wrangler Technical Forum 6 02-11-2011 09:04 PM
Bent fuel/brake lines question blades012 TJ Wrangler Technical Forum 5 07-11-2010 05:25 PM
Fuel lines that connect up top to the fuel rail bigredcherokee YJ Wrangler Technical Forum 3 09-02-2008 03:05 AM
87 YJ fuel tank and lines running to fuel pump 87yjjeep YJ Wrangler Technical Forum 2 05-27-2007 04:07 PM
Need braided steel fuel lines (from tank to frame lines) drew2000 YJ Wrangler Technical Forum 4 06-18-2006 09:38 AM
