Fuel Line fitting problem. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Fuel Line fitting problem.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deliJeep XJ Cherokee Ulitmate Sliders now available!
Unread 08-05-2009, 11:13 PM   #1
soccergk2003
While removing the fuel lines for installing a new motor one of the four small metal clips inside the fitting that connects to the fuel rail broke. Is this fitting replaceable or do I need a whole new line. This is for the 4.0 motor if that makes a difference.
soccergk2003 is offline   Reply With Quote
Unread 08-05-2009, 11:26 PM   #2
dezertsniper
just go to autozone or napa and get the right sized high pressure fuel injection hose (rubber) Push it over the rib on the metal fuel rail inlet and put two hose clamps on it, one on each side of that rib then do the same on the other end down by the frame and it will be fine Mine have been done like that for about 6 years now with no problems. your system only runs at about 30-40 pounds so that hose will be fine
dezertsniper is offline   Reply With Quote
Unread 08-05-2009, 11:46 PM   #3
soccergk2003
Thanks a lot, was looking through all the fittings people sell and saw nothing like that one. Thanks again.
