Fuel leaks from top of fuel tank on cool mornings.....why? - JeepForum.com
post #1 of 5 Old 06-29-2009, 03:29 PM Thread Starter
jeepdrvr69
I noticed that fuel is leaking from somewhere up on the top of my fuel tank whenever I drive on cool/cold mornings without warming the engine up first. What is the problem?
jeepdrvr69 is offline
post #2 of 5 Old 06-29-2009, 04:06 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
If it leaks from the top of the tank, you have to pull it to fix it anyway, might just as well pull it to find out why. It's not like knowing will make you not have to pull it. It's not tough stuff up there, easy to fix when you find it.
I bet it won't leak if you park on a hill, rear up, so the tank is higher than the valve cover.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 5 Old 06-29-2009, 08:19 PM Thread Starter
jeepdrvr69
Thanks, I guess I was just afraid of what I might find up there after I drop the tank.
post #4 of 5 Old 06-29-2009, 09:30 PM
MJMPC
Bad gasket or cracked rubber fuel lines......
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 5 Old 06-29-2009, 11:57 PM
cresencio
1987 YJ Wrangler
X2
more than likely its a bad gasket or bad fuel line
if your lucky it will be like mine and have a big hole the PO never told you about and have to replace the whole thing
My build
Just break it, that way you have to upgrade
cresencio is offline
fuel tank fuel regulator bustingear TJ Wrangler Technical Forum 3 02-05-2009 09:01 AM
Major vacume in fuel tank causing fuel to spill out bigredcherokee YJ Wrangler Technical Forum 2 09-28-2008 02:35 PM
87 YJ fuel tank and lines running to fuel pump 87yjjeep YJ Wrangler Technical Forum 2 05-27-2007 03:07 PM
fuel tank or Warn fuel skid rattling?? jomax77 TJ Wrangler Technical Forum 3 02-12-2007 04:08 PM
Help! Lock nut on fuel tank for fuel pump H8PVMT TJ Wrangler Technical Forum 6 07-16-2004 12:21 PM
