Fuel Leak, need advice! - JeepForum.com
post #1 of 6 Old 08-07-2011, 03:22 PM Thread Starter
Fouse8806
I have a 1993 jeep wrangler YJ. Its leaking (more like spraying) out of the hose that goes into the metal barb that goes through the fuel filter. its in between the frame and the tub and my body mounts are pretty rusty so i dont think changing the whole line is going to be very easy. Ive heard there are ways to splice the hose. does anyone know how? what size is that hose? any help would be awesome. If its not clear which hose i am talking about email me at mikeshinert@yahoo.com and i will email you pics. Thanks
Fouse8806 is offline
post #2 of 6 Old 08-07-2011, 03:41 PM
Noltz
YJ Wrangler
I don't know what size the hose is 100%, but I suspect 3/8'. The fuel line should be stainless, so I suspect it's the fuel filter that's rotted out. Perhaps grab a fuel filter and try replacing that first. Ask the counter man for new clamps.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4½" & shackles, BFG 33's (sold)
Noltz is offline
post #3 of 6 Old 08-07-2011, 04:42 PM Thread Starter
Fouse8806
its the rubber hose that connects to the stainless tube. its cracked. i just dont know what to do to fix it because i cant route the hose the same way without getting my body mounts out
post #4 of 6 Old 08-07-2011, 04:51 PM Thread Starter
Fouse8806
post #5 of 6 Old 08-07-2011, 05:32 PM
Noltz
YJ Wrangler
Hm, kinda poopy picture. That's the line that feeds from the sending unit to the stainless lines. The fuel filter is father up from that, in front of the axle, left side of Jeep. Unless someones added a second filter there.... then who knows.
If you can get a clearer picture I could see more, but it looks like you have enough slack in the rubber hose to remove, cut and install with new clamp if needed.
-Noltz
Noltz is offline
post #6 of 6 Old 08-07-2011, 10:18 PM
GottaYJ
If the hose is leaking its a dealer only part. about 25 bucks.
GottaYJ is offline
fuel , gas , hose , leak
TJ exhaust leak advice MillerTimeTJ TJ Wrangler Technical Forum 1 04-19-2011 06:02 PM
Fuel leak from fuel filter? DEERSLAYER94YJ YJ Wrangler Technical Forum 13 03-31-2010 08:21 PM
Vacuum leak, now fuel leak? jgillespie YJ Wrangler Technical Forum 4 01-25-2010 10:16 AM
95 Radiator Leak - Need Advice Alan & Tanya C. YJ Wrangler Technical Forum 6 05-11-2006 08:28 PM
Need vacuum leak advice !! YJ Newby YJ Wrangler Technical Forum 4 12-09-2005 12:35 PM
