fuel issues,where do i start ? - JeepForum.com
post #1 of 11 Old 06-24-2015, 04:17 AM Thread Starter
azjeepbud
I started noticing some hesitations while driving my 89 2.4l. I replaced the fuel filter first, but still have the same hesitations and they are more frequent now. Is it the fuel pump?... hit me back when you have time before I invest in one, and recommendations on where to buy.
Thanks....
azjeepbud is offline
post #2 of 11 Old 06-24-2015, 05:17 AM
Que89YJ
What makes you think it's a fuel issue? You should have a 2.5L TBI.
Que89YJ is offline
post #3 of 11 Old 06-24-2015, 08:35 AM
mike134
Don't buy a fuel pump yet. The install process is not the easiest of repairs and you're not sure it is the culprit. You should make sure your maintenance is up to date first. Could you answer the following questions?
Is there any difference between when the engine is hot/cold?
Does it hesitate while under load or while near idle?
Check maintenance issues first! Please confirm that the following are relatively new (within the last couple years perhaps?):
New fuel filter ($7)
New spark plugs ($10)
New plug wires ($30-100 depending on favorite flavor of price)
New distributor cap ($14)
New (or cleaned) air filter ($14)
lubricate the throttle cable
Remove the cables from the battery terminals, engine block grounding strap, firewall grounding strap. Clean them with a wire brush and put dielectric grease on them (available from autozone for $1.49 at the counter)
Bottle of throttle body cleaner ($5) Clean throttle body. when finished, spray it on all vacuum hoses while at idle, listen for a change in RPM.
If all of that is up to date, go to autozone and borrow the fuel pressure gauge. It is free to borrow if you leave a deposit. check your fuel pressure. You shouldn't install a new fuel pump until you are certain the fuel pressure is incorrect.
For hesitation, you'd be surprised how a new fuel filter and spark plugs can really improve the engine performance.
mike134 is offline
post #4 of 11 Old 06-24-2015, 12:10 PM Thread Starter
azjeepbud
hey mike all tune up is new, new battery and cables, i'll check the t/body, I can feel it under load, and and sometimes at idle, I spotted it a few days ago, after driving it about 8 miles in morning. nothing when driving home after work. started her up the next am and she was cutting out, so just put her back in the driveway. did some research on pump removal, not a problem..someones gotta do it. hit me back....
post #5 of 11 Old 06-24-2015, 12:16 PM
mike134
the throttle body and IAC is usually only the issue if the problem occurs at idle speeds. If it is happening under load, then it could very well be the pump. It's not terrible to drop the tank, but it isn't simple either. Some people will just cut an access port through the cargo area. This makes it field serviceable. You'll just want to check the pressure first before doing the pump though.
Just to be sure, double check on the fuel filter direction. We all know that we put it in correctly, until we find out that we didn't.
mike134 is offline
post #6 of 11 Old 06-24-2015, 12:26 PM Thread Starter
azjeepbud
fuel filter is in correctly, cool, i'll check pressure, off the top of your head, what is a good pressure reading?
post #7 of 11 Old 06-24-2015, 12:37 PM
mike134
I think it was 14.5 psi for the 2.5L TBI.
mike134 is offline
post #8 of 11 Old 06-24-2015, 07:32 PM Thread Starter
azjeepbud
thanks mike....
post #9 of 11 Old 06-25-2015, 03:53 AM
Que89YJ
Does it happen when cold or does it only happen when it's warmed up?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #10 of 11 Old 06-25-2015, 08:21 PM Thread Starter
azjeepbud
cold.....
post #11 of 11 Old 06-25-2015, 08:27 PM
Que89YJ
O2 sensor or an exhaust manifold leak. Try disconnecting the o2 sensor and see if it still happens.
Fault codes:
No Start:
Que89YJ is offline
