Fuel Injectors - Which one for upgrade? - JeepForum.com
post #1 of 1 Old 08-09-2010, 06:00 PM Thread Starter
Jeeper_YJ
I thought I read that the stock fuel injector was 248cc/21lb for a '93 HO 4.0 motor (HO is key).
Looking for the correct 4-hole Bosch part number? Or color injector?
'97 Cherokee, 99+ intake, 62mm TB, 703 injectors (new), k&n intake, Hypertech III, 180* stat (1/8" drilled hole), 2.5" manifold 2 tail pipe (Hooker Maxflow & hi flow cat), Perf header, 4.5" zone lift, 32" GY Dura Trac, Rear head rests. Comp cam "231" & Perf head (LS1 BIG valves 2.02/1.62). 3 row alum radiator.
Jeeper_YJ is offline
Upgrade injectors,Fuel pressure regulator and Throttle body on 2.5 Ironworker709 YJ Wrangler Technical Forum 6 04-02-2014 08:19 AM
Are TJ fuel injectors any better than YJ injectors? Drdan524 YJ Wrangler Technical Forum 10 04-01-2009 03:52 PM
Need advice on where to find drop in upgrade injectors supraman1990 YJ Wrangler Technical Forum 15 05-17-2008 09:29 AM
Fuel injectors TSEJEEPERS YJ Wrangler Technical Forum 1 11-03-2006 12:02 PM
Exhaust Manifold Help : Lost on how to remove Fuel injectors, wiring, and fuel rail. Mr. Notorious YJ Wrangler Technical Forum 9 08-10-2005 07:00 PM
