Fuel Injectors - JeepForum.com
 9Likes
post #1 of 46 Old 07-25-2016, 07:58 PM Thread Starter
calpbs
Fuel Injectors
I have read that 4 hole injectors off a NEON are a nice upgrade from the factory single hole injectors. No better economy but throttle response is noticeable. I am assuming PT cruisers are the same as NEONs so what years will work or will all years work? Does anyone have experience with this?
I have done so much with so little for so long, I can do anything with nothing forever.
Charlie Lamar
Ringgold, GA
calpbs is offline
post #2 of 46 Old 07-26-2016, 07:52 AM
Que89YJ
Look at this thread and follow the link posted.
http://www.jeepforum.com/forum/f12/i...grade-1433205/
Que89YJ is online now
post #3 of 46 Old 07-26-2016, 09:30 AM
tom_sprecher
Does the 2.5 and the 4.0 use the same injectors? The fuel system from the fuel filter to the injectors is the only major system I have not gone through and will next winter.
Tom
tom_sprecher is offline
post #4 of 46 Old 07-26-2016, 04:59 PM Thread Starter
calpbs
Excellent link and I may have access to some of those. I could not link into the 4 banger forum without joining so I did not read that link, I have th HO 4.0. Going to pull them and maybe post pics before I install.
Charlie Lamar
Ringgold, GA
calpbs is offline
post #5 of 46 Old 07-26-2016, 05:30 PM
shaggyjim
Cautiously Optimistic!
shaggyjim's Avatar
I just Installed some Bosh EV6 four hole injectors a few weeks ago on my 4.0l. My old injectors were still in good shape and clean and clear of deposits. I must say I haven't noticed any improvement in power or fuel economy but my Jeep sure starts and idles nicer now.
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #6 of 46 Old 07-27-2016, 07:21 AM Thread Starter
calpbs
One of the things I have read on this forum is the heat cycles take a toll on the the injector O-rings and that they periodically need replacing. I replaced them on an old jeep before but it was along a bunch of other mods so I don't remember. It may be that the new seal on the injectors is all the improvement there will be. It makes sense that fuel dispersion and atomization would be better. I don't see a down side.
Charlie Lamar
Ringgold, GA
calpbs is offline
post #7 of 46 Old 08-01-2016, 02:56 PM
kg6mov
Hears the voices
kg6mov's Avatar
There are two replaceable parts on our (and the neon) injectors that matter.
The o-rings, and the filters. You can try just replacing those on your current injectors to see if it helps: http://www.ebay.com/itm/6-Cylinder-T...tWZmoN&vxp=mtr
kg6mov is online now
post #8 of 46 Old 08-01-2016, 04:29 PM Thread Starter
calpbs
Filters, the in line fuel filter on the frame is the only one I am aware of which I replaced.
Charlie Lamar
Ringgold, GA
calpbs is offline
post #9 of 46 Old 08-01-2016, 05:59 PM
kg6mov
Hears the voices
kg6mov's Avatar
There are little screen filters inside the injectors (follow the link, little brass tipped things).
They get buildup on them overtime.
post #10 of 46 Old 08-01-2016, 06:27 PM
shaggyjim
shaggyjim's Avatar
Jim...
post #11 of 46 Old 08-01-2016, 07:31 PM Thread Starter
calpbs
Wow thats awesome, I pick up such good info from this forum. I still wonder if the 4 hole injector is not the better option. I love this info
Charlie Lamar
Ringgold, GA
calpbs is offline
post #12 of 46 Old 08-01-2016, 07:45 PM
shaggyjim
shaggyjim's Avatar
If your going to do it get the bosh EV6 four hole injectors. You would be amazed how much better they atomize fuel.
Jim...
post #13 of 46 Old 08-01-2016, 07:55 PM
shaggyjim
shaggyjim's Avatar
I went with this guy when I got mine. Its a cool video if you have a few.
Jim...
post #14 of 46 Old 08-02-2016, 07:38 AM Thread Starter
calpbs
https://www.youtube.com/watch?v=WIhkGBNIpn8
That is an excellent demonstration and the 4 hole or nozzle effect rings true to my chemical engineering background. I am absolutely sure this guy is not manufacturing new injectors but instead cleaning and testing take-offs. Seems to me that if I am given free injectors and replace the o-ring and filter and run injector cleaner through them I would be $140 to the good.
$160 injectors free
$20 o-ring and filter
$140 value.
I am relatively sure these injectors are not rebuildable so a clean injector is likely to flow virtually identical. I love this type of information.
Charlie Lamar
Ringgold, GA
calpbs is offline
post #15 of 46 Old 08-02-2016, 09:27 AM Thread Starter
calpbs
So I am going to investigate the injectors today if it does not rain on me. I am assuming from the pics that the EV6's are yellow and may have a number on them and may not. Most likely they will have some type of Bosch marking. I now am curious as how to get optimal fuel system efficiency. New filters, o-rings, fuel line filter, Injectors. Seems like the only thing left is the fuel pressure regulator. Is it better to stay with the stock regulator or get an adjustable one? Does a few pounds of pressure really make much of a difference? As I could be considered old School what is the prevailing opinion. Final question, who else sells the injector screens other than ebay, Advance or auto zone?
Charlie Lamar
Ringgold, GA
calpbs is offline
