Fuel Injector Wiring - Page 2 - JeepForum.com
post #16 of 21 Old 01-19-2014, 09:22 AM Thread Starter
thE_iyE
Thanks.
thE_iyE is offline
post #17 of 21 Old 01-19-2014, 10:09 AM
Que89YJ
Do you have the ecu pin out?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #18 of 21 Old 01-20-2014, 09:12 AM Thread Starter
thE_iyE
No... I was thinking that the wires were going to match-up on that end.
thE_iyE is offline
post #19 of 21 Old 01-20-2014, 05:30 PM
Que89YJ
The wire color is different from year to year but the location in the ecu connector is the same. You can look at any 91/95 ecu pin out and look at your ecu connector and it will be the same location for the injectors. Look at your connector and what ever injector wire is it the location in the ecu connector should go to the correlating injector.
Fault codes:
No Start:
Que89YJ is offline
post #20 of 21 Old 01-20-2014, 06:30 PM Thread Starter
thE_iyE
Do you have a pi out diagram?
thE_iyE is offline
post #21 of 21 Old 01-20-2014, 07:32 PM
Que89YJ
I posted it in the previous post. Look at the injector location on the connector and see what wire is there. Match it to the injector.
Fault codes:
No Start:
Que89YJ is offline
