Fuel injector question - JeepForum.com
post #1 of 2 Old 10-10-2002, 01:35 PM Thread Starter
Jay-P
Does anyone know if the ECM totally kills an engine if it isn't recieving a signal from one of the injectors? Will it just kill the motor to prevent any type of internal damage from an extremely lean cylinder?
I've been having a stalling problem with my jeep for the last little while. I finally broke down and took it to the dealer and they came up with a code for a loose connection to one of the injectors. They fixxed that and have had no stalling issues with the jeep since.
The only thing i'm worried about is that the jeep will run fine from time to time, then start to stall out again (no sputtering, or rough running like i would acssociate with no fuel to one cylinder). I just hope this isn't what is happening with it now at the dealership, then when i get it home it will start to stall again.
Any ideas?
1992 YJ + 2012 JKUR
Jay-P is offline
post #2 of 2 Old 10-10-2002, 11:48 PM Thread Starter
Jay-P
Original posts on this whole issue can be seen here, and here.
If anyone has any input for me it would be much appreciated.
Thx.
Jay-P is offline
Question about depressurizing fuel system and removing injector rail superslayer TJ Wrangler Technical Forum 23 12-30-2009 12:04 PM
fuel injector ZachAttack923 TJ Wrangler Technical Forum 1 04-27-2009 01:27 PM
Exhaust leak? And Fuel injector Question JeepItUP YJ Wrangler Technical Forum 10 05-26-2008 01:52 PM
fuel injector question bradshaw TJ Wrangler Technical Forum 3 05-21-2007 04:47 PM
fuel injector question - what oil? Freakshow TJ Wrangler Technical Forum 1 08-30-2005 04:48 PM
