-   -   Fuel guage not working correctly dying at idle (http://www.jeepforum.com/forum/f12/fuel-guage-not-working-correctly-dying-idle-1547065/)
Wrangler11 07-09-2013 05:46 PM
I ran out of gas today and my fuel gauge was reading a half tank. I thought when fuel gauges didn't read correctly it was either fuel or empty?
I added two gallons and then when to the gas station. As I pulled put the jeep in reverse to pull into my driveway the rpms dropped and the jeep stalled. What would cause this to happen?
Siva283 07-09-2013 07:46 PM
Fuel pump. Check the ground at the parking brake. The gauge and pump share a ground and it grounds at the brake assembly
Sent from my SPH-L300 using JeepForum
jeepstillhaslif 07-09-2013 08:10 PM
You happen to have a pic of where the ground is and what it should look Lk near brake
Siva283 07-10-2013 04:40 AM
I can get a pic tonight. I am headed to work right now
Tblair23221 07-10-2013 06:18 AM
If it is by the ebrake, here is an image that might help.
http://i1313.photobucket.com/albums/...ps1a6c53b8.jpg
The wire was actually on the other side of the bolt (nut side) but I had moved mine to the other side while testing it. The wire itself can be hard to see but once you see the bolt, you should just be able to reach your finger around the back and find it.
Wrangler11 07-10-2013 07:40 AM
It is really annoying every time I stop it dies. It's really annoying in traffic.
Wrangler11 07-10-2013 08:21 AM
Could the iac just need a good cleaning?
jeepstillhaslif 07-10-2013 08:51 AM
Thanks for the pic. A little hard to understand pic at first but prolly be easier once I feel under near my e brake. So can we clean this area of rust or just make sure contact is good. Do we disconnect the bat
Tblair23221 07-10-2013 12:44 PM
To give you a bit of perspective, to the side of the bolt you can see the lever for the brake release. Also, if right when it stalls (or when it won't start back up) the fuel gauge on your dash pegs to Full, it is most likely the ground.
Wrangler11 07-10-2013 05:55 PM
It's always started back up.
Wrangler11 07-11-2013 11:15 AM
I found a hose with a crack. Replaced it. The problem continues. I am going to clean the iac and throttle body and replace the tps this weekend and see if that solves the problem.
Siva283 07-11-2013 12:00 PM
You really need to check that ground.
Wrangler11 07-11-2013 05:09 PM
There is not a ground by the ebrake. Could the ground be somewhere else?
Siva283 07-11-2013 05:39 PM
If not the ebrake check the one by the oil dipstick. I have heard it being eithier place. Mine is by the ebrake though.
Wrangler11 07-11-2013 05:57 PM
There is a similar wire like picture by the dip stick. Cleaned it. It looks good. Problem is still there.
The symptoms do sound like it could be the ground. Maybe it's two completely different problems.
The time now is 06:45 PM.
