Fuel guage inaccurate - JeepForum.com
post #1 of 11 Old 08-19-2011, 02:23 PM Thread Starter
bogleparsons
OK guys let me tap into your wealth of knowledge.
When my fuel gauge is at 1/2 it means yer empty.
Pegs out past full when filled up, this normal or is there a way to adjust the float?
Also my temp gauge only goes up to like 140F i replaced the sending unit and ohm checked the wire, that mean the gauge is fubar? whats a good way to check the engine temp to verify gauge accuracy?
bogleparsons is offline
post #2 of 11 Old 08-19-2011, 03:14 PM
deermjd
My gas guage does the same thing. I'd like to know how to fix this too.
94 ZJ Laredo (sold)
98 ZJ TSI (sold)
92 YJ 4.0
deermjd is offline
post #3 of 11 Old 08-19-2011, 03:25 PM
JWBooth
Lemme join the club
Mine too... I fill up around 190-200 miles to be safe and just reset the trip odometer each time I top it off.
So, any fixes?
Please Note: My actual location is a lead box in Sassafras Cove.
-Proud Co-Founding Member of the Dirtbag Brotherhood
-Ringleader of the WhiteTrash Circus.
**LONG LIVE 4-LOW**LONG LIVE 4-LOW**LONG LIVE 4-LOW**
JWBooth is offline
post #4 of 11 Old 08-19-2011, 03:33 PM
youngjeepr
190- 200!!!! wow i didnt know it went that high im empty around 150
youngjeepr is offline
post #5 of 11 Old 08-19-2011, 03:41 PM
jgillespie
Check sending unit. I wouldnt hesitate to replace it. The stock gauges are so inaccurate that they are nearly dead weight.
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
jgillespie is offline
post #6 of 11 Old 08-19-2011, 03:49 PM
clarkjdg
clarkjdg's Avatar
Mine goes all the way to empty "BUT" when it get to full I'm under a half a tank and when it says 1/2 you have got right at 20 miles to go. But I just go by odometer. 160 to 180 depending on a head wind , with a push I might even hit 200
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #7 of 11 Old 08-19-2011, 04:30 PM
R3V413
Here is a thread that I started that will not only help fix the common ground problem with the fuel gauge but the other gauges that have a mind of their own..
http://www.jeepforum.com/forum/f12/g...r-own-1250074/
JEEP=Just Empty Every Pocket
"Politics is war without bloodshed while war is politics with bloodshed."-Mao Zedong
"For Those Who Fought For It, Freedom Has A Flavor The Protected Will Never Know"-Unknown
00 TJ on 31x10.5x15's- DD
89 YJ-Under the Knife
R3V413 is offline
post #8 of 11 Old 08-19-2011, 05:57 PM
Missouribound
Still have the BBD? Change to a Weber and save a few bucks on gas and get a consistently better running YJ.
Missouribound is offline
post #9 of 11 Old 08-19-2011, 07:01 PM
clarkjdg
clarkjdg's Avatar
???? Well mine runs better with my Weber but the gas mileage 160, to 180 I don't think it is to Hot for fuel economy, You pay for what you do to your Jeep, size Lift, size Tires, and all the Extras that catch wind, Im running a 6 on 33's and "youngster" shows to have a 4 banger on 35's there is my 10 mpg gain. You Play and you Pay, but I thought that was the main thing about a Jeep was PLAYING!!!!
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
clarkjdg is offline
post #10 of 11 Old 08-19-2011, 07:14 PM
oldtime_ironman
This is what you want:
http://www.jeepforum.com/forum/f12/r...ter-how-991307
I did this a few mos ago and its been great ever since. Basically just cleaning all the gage connectors and grounds.
Hope that helps.
oldtime_ironman is offline
post #11 of 11 Old 08-19-2011, 07:47 PM
clarkjdg
clarkjdg's Avatar
Hope that helps.
Thanks!!!!!!! I'm going to see if it will fix mine!
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
clarkjdg is offline
inaccurate gas guage jamesl57 YJ Wrangler Technical Forum 6 11-09-2009 09:34 AM
Fuel Gauge Inaccurate: reads 1/4 tank when empty OPlo YJ Wrangler Technical Forum 17 07-15-2009 08:01 PM
Inaccurate Gas Guage? MCTampa YJ Wrangler Technical Forum 10 02-13-2007 05:35 PM
Fuel guage ? Got2HaveLights TJ Wrangler Technical Forum 3 01-13-2006 07:52 AM
fuel guage? freshie24 YJ Wrangler Technical Forum 2 03-24-2004 01:25 PM
