Fuel Gauge Tick - JeepForum.com
post #1 of 3 Old 06-08-2012, 06:30 AM Thread Starter
JDel
1987 YJ Wrangler
Fuel Gauge Tick
Hey Everyone!
I've owned my jeep for about a month now and after doing all the standard tune up stuff i'm starting to work on things that might take a little more time. My fuel guage is the first on my list. when running, the guage jumps all over the place and I couldn't tell how much fuel I had in the tank. yesterday I changed out the pigtail that goes from the tank to the guage, it was all corroded inside so i thought that would do the trick, it didn't and it still has a slight tick. any ideas what this could be? has anyone else had this problem?
JDel is offline
post #2 of 3 Old 06-08-2012, 08:36 AM
Que89YJ
Everyone who owns a Jeep! If the guage is reading accurate with a slight "tick" then you are way way ahead of most of us. Many of us clock the fuel level against the miles driven. One though is the tick could be an issue with the radio coupling to the harness. Does it bounce with the key on(engine not running) and the radio and all the accessories off? One more issue that is common is corrosion on the cluster. look at this:
http://www.jeepforum.com/forum/f12/r...er-how-991307/
Que89YJ is offline
post #3 of 3 Old 06-08-2012, 08:42 AM
E-TICKETRIDE
X2
When I bought mine it was terrible. New radio installed and works like new.
If it doesn't work use a bigger hammer.
E-TICKETRIDE is offline
fuel , fuel gauge
new 2003 jeep owner .... i hear a new tick tick tick... gskills TJ Wrangler Technical Forum 21 04-23-2012 08:08 PM
Instrument gauge wiring harness, Fuel Gauge Problem 1990 YJ Jstout724 YJ Wrangler Technical Forum 3 03-29-2012 02:17 PM
Cold Engine Says Tick Tick Tick Fischey TJ Wrangler Technical Forum 16 07-02-2009 03:45 PM
Tick tick tick? Weird noise thebulkinator TJ Wrangler Technical Forum 9 10-14-2004 08:15 PM
Engine Tick??? Valve's or Fuel injector's nuclear ape YJ Wrangler Technical Forum 2 01-17-2003 09:53 PM
