Fuel Gauge Problem - JeepForum.com
post #1 of 11 Old 09-05-2011, 09:56 AM Thread Starter
salsomano1a
Fuel Gauge Problem
hi my fuel gauge when i turn right or left it goes to empty and then when the jeep its going straight it goes back to where it was, but its never steady, it this normal ?? thanks for all the help.
salsomano1a is offline
post #2 of 11 Old 09-05-2011, 09:59 AM
G30SFF250
This is odd!
I think it would more odd if it worked right.
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline
post #3 of 11 Old 09-05-2011, 11:00 AM
cstone94
Its the gas sloshing around and moving the float. Its a jeep thing.
95' YJ - Warn Bumpers/Tire Carrier/Winch - 2.5L - 6" Skyjacker Suspension Lift - 4.10's - Locrite Locker - Dana 35/30 - 35" BFGoodrich KM2's
11' F250 - DD
1982 Toyota Pick-Up - Spray-On Yellow Rhino Lined - Chevrolet 305 H.O. - SM465 - NP208C - All-Pro Off Road 5" Springs - 35x15.50x15 Super Swampers
cstone94 is offline
post #4 of 11 Old 09-05-2011, 12:32 PM Thread Starter
salsomano1a
what do you mean by sloshing around and moving the float?
post #5 of 11 Old 09-05-2011, 02:38 PM
tdewit
The tank's float movement is inline with the vehicle. It should show a different level going up and down hill, but left right
tdewit is offline
post #6 of 11 Old 09-05-2011, 07:13 PM
cstone94
The float on the sending unit, it floats on top of the gas which tells the sending unit how much fuel is there and then you read it on the gauge.
cstone94 is offline
post #7 of 11 Old 09-05-2011, 08:30 PM
Marky1
How much work is there to fix or replace the sending unit ? My son's fuel gage is not working. thanks.
Marky1 is offline
post #8 of 11 Old 09-06-2011, 06:14 AM
tdewit
No easyway out, you have to remove the gas tank completely. Once the tank is out, it's a couple of bolts to replace the sending unit.
Here's a write-up
http://www.jeepforum.com/forum/f12/1...moval-1167482/
Before putting the tank back, do this: http://www.jeepforum.com/forum/f12/9...panel-1195157/
tdewit is offline
post #9 of 11 Old 09-06-2011, 08:25 AM
Que89YJ
Hey Marky1 you should check the guage first. The YJ guages are known to be an issue as well as the sending unit.
Que89YJ is offline
post #10 of 11 Old 09-06-2011, 09:22 AM
bharris68
Daily Driver
bharris68 is offline
post #11 of 11 Old 09-06-2011, 07:37 PM
MJDriver
MJDriver's Avatar
I'm not sure if this was in the write-up, but when I replaced my fuel pump I also cleaned the sending unit sensor:
Unfortunately, no picture, but it's easy to find. Where the swing arm for the float attaches to the assembly there will be a little box (about 1" long by 1/2" high). Gently pry open the box and you should see a crescent shaped coil of copper wire - this is where the signal is sent from.
Wearing rubber gloves, take the assembly someplace in the open, not near any plant or animal life, and spray the crescent with electrode cleaner (pick up at auto parts store of Home Depot). I used up almost a whole can, moving the arm and shooting everything from different directions.
The gauge still moves if I floor it, or turn hard, but that is to be expected. It no longer dances all over the place, or shows full when it's empty, and vice versa.
Good luck.
Current - 1993 Wrangler 2.5 - mostly stock
Previous - 1989 Comanche Pioneer 4x4 Long Bed/Metric Ton Pkg
4.0, AT, D44 w/ Trak-Lok RIP
MJDriver is offline
Fuel Gauge problem Fuxton YJ Wrangler Technical Forum 7 09-09-2009 08:32 AM
fuel problem and gauge white_elephant YJ Wrangler Technical Forum 4 09-03-2009 12:01 AM
87 YJ fuel gauge problem roadglide YJ Wrangler Technical Forum 7 03-08-2008 07:53 PM
87 YJ fuel gauge problem roadglide YJ Wrangler Technical Forum 1 03-08-2008 04:59 PM
Problem with Fuel Gauge? RHaverland TJ Wrangler Technical Forum 10 04-21-2003 08:01 PM
