fuel gauge is at max and none of the other gauges or lights work? - Page 2 - JeepForum.com
post #16 of 24 Old 04-05-2010, 08:54 AM Thread Starter
chosos
1987 YJ Wrangler
thank you - ill check it today after work.
chosos is offline
post #17 of 24 Old 04-05-2010, 09:11 AM
Reverb
Yeah you can't miss it - its a big thing looks like this (except covered in oil if your 4.2 is like mine)
Reverb is offline
post #18 of 24 Old 04-05-2010, 03:33 PM Thread Starter
chosos
1987 YJ Wrangler
sadly, I do not have anything like that in mine.
chosos is offline
post #19 of 24 Old 04-05-2010, 03:52 PM
firebrick43
it might have a black plastic top
firebrick43 is offline
post #20 of 24 Old 04-05-2010, 04:48 PM Thread Starter
chosos
1987 YJ Wrangler
found it. its all the way on the rear pass side - below the last 2 spark plugs and valve cover gauge works.!
chosos is offline
post #21 of 24 Old 04-06-2010, 09:53 PM
bharris68
Daily Driver
Try this - let me know if it works: http://www.jeepforum.com/forum/f12/r...er-how-991307/
bharris68 is offline
post #22 of 24 Old 04-07-2010, 05:53 AM Thread Starter
chosos
1987 YJ Wrangler
sorry, i thought I updated this - my gauges are all working. and actually, that thread you posted was partially what helped me out. the rest of the mess was that the previous owner unhooked the coolant temp sensor and the oil pressure sensor.
The only issue im having currently, is that the dimmer does not function correctly, and I've taken it apart and its all clean. It either turns the lights on (full power) or off. Its not a terrible problem - and if I ever upgrade to LED's, its perfect i guess. :-)
chosos is offline
post #23 of 24 Old 04-07-2010, 06:49 PM
bharris68
Daily Driver
Sounds to me like the dimmer switch is shot. I'll bet that if you were to take the headlight switch apart and clean it up (Probably greasy/dirty) it will work again. Either that or a simple replacement switch will solve the problem.
post #24 of 24 Old 04-07-2010, 07:39 PM Thread Starter
chosos
1987 YJ Wrangler
i took the dimmer switch apart - no go. im not gonna worry too much about it as long as the llights work
chosos is offline
Gauges and lights dont work Yamahafreak93 YJ Wrangler Technical Forum 1 04-06-2010 09:54 PM
Battery died and now no gauges/lights/nada work ben8jam TJ Wrangler Technical Forum 16 02-23-2010 01:43 AM
Electrical gremlin, low volts, and gauges and lights don't work bclg YJ Wrangler Technical Forum 2 04-25-2009 10:36 PM
fuel gauge???will this work??? XJ Beater YJ Wrangler Technical Forum 4 01-24-2007 08:05 PM
Two Gauges Don't Work - Gauge or Sender? Tshark299 YJ Wrangler Technical Forum 9 04-19-2004 08:22 AM
