Fuel filter replacement - How do I depressurize fuel system? - JeepForum.com
post #1 of 14 Old 11-22-2008, 01:45 PM Thread Starter
Rproject
1987 YJ Wrangler
In looking at the Chilton's manual it says to relieve the pressure in the fuel system prior to replacing the fuel filter. Specifically it says, "Release the fuel system pressure. Refer to the procedure outline earlier in this section." Only problem is, there is no procedure outline earlier in the section. ?????
So, how do I relieve the pressure?
Rproject is offline
post #2 of 14 Old 11-22-2008, 02:15 PM
CheapSunglasses
2007 XK Commander
I'm not sure, but maybe if you crack open the gas cap.
"The Bannana Channell, Programming With Appeal"....Stay Tuned For a Bunch More!
CheapSunglasses is offline
post #3 of 14 Old 11-22-2008, 02:17 PM
bcwheeler
Their should be a Schrader type valve on your fuel rail that you can push on. Sprays gas out of it so hold a rag or something over it. Plus unscrew your gascap on the other end.
bcwheeler is offline
post #4 of 14 Old 11-22-2008, 02:18 PM
chadroc
I'm not sure if it's correct or not, not I just loosen the fittings on the filter. A little gas leaks out, it depressurizes and I then change the filter. It works for me
chadroc is offline
post #5 of 14 Old 11-22-2008, 02:50 PM
Exparrot
Exparrot's Avatar
BCWheeler's right. On the drivers side of the top of the engine, there's a valve with a black cap sitting right on the top of the frame rail. Remove the cap, rag over top, and press the valve (looks like a tire valve stem) with a flathead screwdriver. A little gas should shoot out.
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
post #6 of 14 Old 11-22-2008, 03:15 PM
pat8942
pat8942's Avatar
I do it the same way.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #7 of 14 Old 11-22-2008, 03:34 PM
YJames90
YJames90's Avatar
I just removed the filter. A little gas dripped out. I kept the rubber hose pointing up so no gas came out
My 2.5 to 4.3 swap thread
YJames90 is offline
post #8 of 14 Old 11-22-2008, 03:54 PM Thread Starter
Rproject
1987 YJ Wrangler
At this point I'm thoroughly convinced that what I am attempting to change is the ORIGINAL fuel filter with 159K miles on it. The shroud bolts are so frickin' rusted I can't believe that they're ever been out before. I've got 2 down and 2 to go. What an absolute PITA. It shouldn't be this hard.
Rproject is offline
post #9 of 14 Old 11-22-2008, 03:58 PM
swedishdwarf
swedishdwarf's Avatar
The easiest and cleanest way to depressurize the fuel system is to start it up and pull the fuel pump fuse. When it stalls, your fuel pressure is gone.
You can't teach an old dogma new tricks.
swedishdwarf is offline
post #10 of 14 Old 11-22-2008, 04:30 PM Thread Starter
Rproject
1987 YJ Wrangler
That's great, but I still have 2 bolts to remove before I can even GET to the flippin' filter. 3.5 hours and only have 2 bolts out. At this rate I'll have the fuel filter replaced sometime around the New Year.
Of course the 2 that are out are the "easy" 2. The two that face mount to the frame rail are being absolutely insane. Both are so rusted that they don't even look like bolts anymore, but of course they have enough bite and enough metal under all the dang rust that I can't just break 'em off.
Napalm, that's what I need, napalm.
Rproject is offline
post #11 of 14 Old 11-22-2008, 06:59 PM
bcwheeler
Yea torch it off, Its not like gas is flammable...
post #12 of 14 Old 11-22-2008, 10:15 PM Thread Starter
Rproject
1987 YJ Wrangler
FINALLY got the project done. Had to dremel off 2 of the bolts. Slotting them didn't work, had to completely cut off the heads. Overall project time? 8.5 hours. What a nightmare.
Now with the project done, the next question comes; How important is this shroud? I can get 2 of the bolts back in relatively easily, the other 2 forget about it. They're toast and so are the holes.
I guess if it's important enough, I can always put it back on with 2 screws, then zip tie it to keep it from coming loose.
Thoughts?
Rproject is offline
post #13 of 14 Old 11-23-2008, 09:08 AM
YJames90
YJames90's Avatar
I left the shroud off. Not thats its the correct way to do it but mine was a mess
YJames90 is offline
post #14 of 14 Old 11-23-2008, 09:34 AM
T-Mack
i put it back on biut thays just me but it could realy ruin a day if it took some damage
T-Mack is offline
Fuel Filter Replacement B_Brookshire YJ Wrangler Technical Forum 5 05-23-2008 12:18 AM
fuel filter replacement Dave M TJ Wrangler Technical Forum 14 10-20-2006 06:27 AM
Fuel Filter Replacement on a 91 YJ 4.0L JaySpencer66 YJ Wrangler Technical Forum 9 07-27-2006 09:29 PM
Fuel Filter replacement BeirBrennerE30 YJ Wrangler Technical Forum 11 04-18-2006 05:19 PM
fuel filter replacement? rolledthatho YJ Wrangler Technical Forum 4 01-25-2006 07:37 PM
