Fuel Filter Replacement on a 91 YJ 4.0L - JeepForum.com
post #1 of 10 Old 07-26-2006, 03:07 PM Thread Starter
JaySpencer66
First, where is it? I have heard a nasty rumor here that it is on the frame rail by the driver's side rear wheel. Any tricks to getting it replaced/accessing it? I want to ditch it because in spite of replacing all the ignition components, coil, distributer, roter, plugs, wires, cleaned my cone filter, etc, I am still getting a little hesitation and stall on start up. I think the spark is good, I know the air is good, so that leaves me with fuel to address next in the holy triangle of air/fuel/spark.
I could do the alternator/distributer/battery combination too, but if it's as "simple" as a fuel filter then I would like to do that and be done with it, ya know?
Any advice is appreciated.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
Member #1 of the "I Hate Torx Club!"
~anyone with a Jeep is an automatic member, and anyone can be member #1~
JaySpencer66 is offline
post #2 of 10 Old 07-26-2006, 03:13 PM
dadstoy
It's not bad at all. It is inside the frame rail. It is just the bolt that holds the bracket on and the two hose clamps. I used vise grips to pinch off the hose from the front to stop the flow of gas from there. Last time I changed mine was in a parking lot by Autozone....
dadstoy is offline
post #3 of 10 Old 07-26-2006, 03:13 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
the filter is $10 at autozone.
the metal guard protecting the filter can be removed with 2 or 3 bolts.
the oem fuel line clamps will probably break so buy a couple extra worm gear clamps when you buy your filter.
make sure you install it in the proper direction.
total replacement time should take you less than 30 mins if you take your time.
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #4 of 10 Old 07-26-2006, 03:14 PM
YJBlues
YJBlues's Avatar
You heard right, but it's easy to get to, 4x 10mm bolts to take off the little skid plate that protects it.
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
post #5 of 10 Old 07-26-2006, 03:25 PM Thread Starter
JaySpencer66
Gaaaahhhhh MORE freaking metric!!! Cool, I like the idea of using the vice grips, I was thinking along those lines to stop the gas flow, either that or moving with blinding speed and no sparks to get the old out and new in with no leaks. . . . .
I also like the idea of small hose clamps, smart, and will do.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
post #6 of 10 Old 07-27-2006, 11:58 AM Thread Starter
JaySpencer66
Cool, all done! I only had two 10 mm bolts holding the skid plate and one 10m nut and bolt holding the bracket closed. I tried to use a vice grip to pinch the hose, no good. Perhaps if I had one that had even jaws it would have worked but that was not the case. I pulled the bottom hose off first and then, after getting an 8oz bath of gas and I think water that was in the filter because it did not smell too bad, I tipped the filter up to stop the flow. I pulled off the two old hose clamps on the bottom and replaced them as I attached the new filter, minding the direction of flow based on the arrow on the filter that tells you which way to go.
Then I rested the new filter in the bracket and pulled the old filter, by going up to keep the hose folded and above the level of the gas in the tank as much as I could.
With the old filter off I pulled the two old hose clamps and put new ones onto the top hose to be ready to attach the new filter.
I brought the line down and slipped it onto the new filter, put the clamps in place and tightened it all up.
Then I tightened the bracket holding the filter, put the skid plate back on, cranked the engine and prayed a little untill it turned over.
As advised it was about a 30 minute job. It took me perhaps 45 minutes because I took my time since it was the first one for me.
I used two ratchets with 10mm sockets to open the clamp, one to hold the nut and the other for the bolt head. The skid plate was held on with 10mm bolts too. The hose clamps were a small SAE but could have been done with a flat head screw driver or small nut driver.
If I have to redo it for any reason I will put the Jeep up on ramps for more space, although it wasn't bad at all without it.
The filter was about $10 and the clamps a few bucks. This is a VERY cheap fix.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
post #7 of 10 Old 07-27-2006, 12:05 PM
ltmke11
ltmke11's Avatar
I dont know if its different on a 91, but I didnt decompress the gas line on my 94 and got a nice gasoline spraying when I replaced mine a few months ago.
ltmke11 is offline
post #8 of 10 Old 07-27-2006, 12:28 PM Thread Starter
JaySpencer66
I didn't decompress my lines either and got a spray that I presume now was pressure related, and perhaps was not gravity induced as I thought earlier. It is fuel injected on the 91+, with a pump in the tank and I think we have the same motor and injection system, minus a few years.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
post #9 of 10 Old 07-27-2006, 02:44 PM
sequel
Did you use fuel injection rated clamps?
1992 Black YJ, 4L I6, 8.8 Rear
3.5" BDS, 5/8" MORE Shackles,
DT-3000s, 16x8 Bajas,
285/75R16 Dunlop Mud Rovers
sequel is offline
post #10 of 10 Old 07-27-2006, 09:29 PM
Raindem
Soooooo... did that fix your hesitation and stall on start up problem?
If it ain't broke... break it.
Raindem is offline
Fuel filter replacement - How do I depressurize fuel system? Rproject YJ Wrangler Technical Forum 13 11-23-2008 09:34 AM
Fuel Filter Replacement finsout TJ Wrangler Technical Forum 2 11-27-2007 04:43 PM
Fuel Filter replacement tommyO YJ Wrangler Technical Forum 3 07-02-2007 01:28 PM
Fuel Filter replacement BeirBrennerE30 YJ Wrangler Technical Forum 11 04-18-2006 05:19 PM
fuel filter replacement? rolledthatho YJ Wrangler Technical Forum 4 01-25-2006 07:37 PM
