Fuel Filter replacement - JeepForum.com
post #1 of 12 Old 04-17-2006, 05:11 PM Thread Starter
BeirBrennerE30
Hello... a friend of mine has a leaky fuel filter in her '95 YJ... so i was wondering how you get those lil metal clips off the rubber lines it connects to and what size nut is used in the bracket(i looks like 10mm but i didnt have a 10 mm socket on me)
any other tips and tricks for the replacement would be helpful... thanks in advance
p.s. if this has been asked before im sorry i searched and found nothing
-Chris
TJ 60th Anniversary Ed.- Stock... for now
BeirBrennerE30 is offline
post #2 of 12 Old 04-17-2006, 05:14 PM
bryris
I hit the exact same problem on those clamps. I just fought with them and mangled them up pretty good, then just put the screw down type on there. I also replaced the rubber hose.
bryris is offline
post #3 of 12 Old 04-17-2006, 08:24 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
mine just had regular ol' hose clamps... loosen them with a 1/4" socket or a flathead screwdriver and a lil twisting and some pulling and walaa, fuel filter falls off and fuel goes everywhere....
i think the bolt was a 10mm but i can't remember... don't you have a socket set? if not, go to sears
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #4 of 12 Old 04-17-2006, 08:30 PM Thread Starter
BeirBrennerE30
yeah i have a socket set... but i was in a rush and couldnt find the 10mm socket... ill buy hose clamps tomorrow and that should solve all my problems... thanks guys
-Chris
post #5 of 12 Old 04-17-2006, 08:30 PM
TellyDSP
Poland and PPV!!!!
My 95 ust had hose clamps. As mentioned, a socket or flat-head will do the trick. Other tips and tricks, release pressure from the system through the schrader valve on the fuel rail and the gas cap. Also, dont lay under the filter when removing. That little can holds a lot of fuel.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #6 of 12 Old 04-18-2006, 06:24 AM
bryris
Well if it still has those factory clamps, a socket won't help. You'll need to put a flat head screwdriver in there and just mangle them up.
bryris is offline
post #7 of 12 Old 04-18-2006, 02:19 PM
wwiihistory
wwiihistory's Avatar
How about buying the correct tool to do the job????
Bought a fuel line clamp removal tool that worked great (on my 2000 ranger anyways). Looks like an "X"...
Happiness is a belt-fed weapon
95 Sahara, 4.0L, 5 spd, Olive/Tan, HT,HD's, 31's,3.07s
Military Jeep club member 1941,1942,1943,1944, and 1945
wwiihistory is offline
post #8 of 12 Old 04-18-2006, 02:28 PM
bryris
That costs money, and it'll never get used again.
bryris is offline
post #9 of 12 Old 04-18-2006, 02:58 PM
TellyDSP
Poland and PPV!!!!
I agree on the whole costs money point, but I'm going to leave you on your own with the never used again part. I know I've swapped my filter more than once. Destroy thos crazy clamps and pick up some standard hose clamps.
-Craig-
95 Rio Grande
07 Ram 1500
TellyDSP is offline
post #10 of 12 Old 04-18-2006, 04:14 PM
bryris
What I am saying is that if there is a tool available to remove those factory crimpings, it is probably not worth the money because they aren't going back on. I will certainly change my fuel filter numerous times, but I have since installed the normal screw down type crimpings so that a screw driver/ratchet can tighten them down.
The factory crimpings will come off with enough intention, then you never have to use them again.
bryris is offline
post #11 of 12 Old 04-18-2006, 04:18 PM
wwiihistory
less than $10 , why wouldn't he use it to change filter in future?
and you won't be redneck hacking it by using a screwdriver.
post #12 of 12 Old 04-18-2006, 04:19 PM
bryris
I think you've misunderstood. Anyway. Worked for me, no problems. Do what you want.
bryris is offline
Fuel filter replacement - How do I depressurize fuel system? Rproject YJ Wrangler Technical Forum 13 11-23-2008 08:34 AM
Fuel Filter replacement tommyO YJ Wrangler Technical Forum 3 07-02-2007 12:28 PM
fuel filter replacement Dave M TJ Wrangler Technical Forum 14 10-20-2006 05:27 AM
Fuel Filter Replacement on a 91 YJ 4.0L JaySpencer66 YJ Wrangler Technical Forum 9 07-27-2006 08:29 PM
fuel filter replacement? rolledthatho YJ Wrangler Technical Forum 4 01-25-2006 06:37 PM
