fuel filter replacement? - JeepForum.com
post #1 of 5 Old 01-25-2006, 01:34 PM Thread Starter
rolledthatho
hey guys, i ran my 4.2 carbed 88 out of gas, i know it got trash sucked up from the bottom of the tank, so im gonna clean the carb and replace the fuel filters, how many are there? where are they located and are there any special tools or tricks to change them?
i searched and found a lot of info but not any tech articles or anything on swapping them out!
TIA
rolledthatho is offline
post #2 of 5 Old 01-25-2006, 01:40 PM
KyleS
If its the same for your 88 as it is for my 95 its located along the frame in the back on the driverside. Its a pretty simple install if I remeber right one end just clips in and the other uses a male\female type of bolt setup for the lines.
KyleS is offline
post #3 of 5 Old 01-25-2006, 01:45 PM
Brown Dog
Vendor
Brown Dog's Avatar
As KyleS says, it's pretty easy. There is a small skid plate under it.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #4 of 5 Old 01-25-2006, 06:21 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
The 4.2's fuel filter is in the engine comaprtment - different than the MPFI engines. It's that metal canister on the fuel line right in front of the carb. It has one input and 2 outputs (one to the carb, one is a return line back to the tank). It's stupid easy to replace.... just loosen the hose clamps for each line to remove them. Shouldn't take more then 5 minutes.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #5 of 5 Old 01-25-2006, 06:37 PM
KyleS
Thanks for clearing that up, I wasn't sure if it was different between FI and carbed or not. Guess I learned something new.
KyleS is offline
Fuel filter replacement - How do I depressurize fuel system? Rproject YJ Wrangler Technical Forum 13 11-23-2008 08:34 AM
Fuel Filter replacement tommyO YJ Wrangler Technical Forum 3 07-02-2007 12:28 PM
fuel filter replacement Dave M TJ Wrangler Technical Forum 14 10-20-2006 05:27 AM
Fuel Filter Replacement on a 91 YJ 4.0L JaySpencer66 YJ Wrangler Technical Forum 9 07-27-2006 08:29 PM
Fuel Filter replacement BeirBrennerE30 YJ Wrangler Technical Forum 11 04-18-2006 04:19 PM
