Fuel Filter - JeepForum.com
post #1 of 19 Old 06-21-2015, 10:39 PM Thread Starter
TestBedOne
Fuel Filter
I'm finally getting to replacing the fuel filter which was very much original to my 92' YJ (154,000 Miles). I got a Crown fuel filter and noticed it had no markings about which side went to the engine. Does it matter which side faces which way? How do I know its facing the correct direction?
I
"Look! Its El Jeepo Loco!"
-Innocent Bystander
TestBedOne is offline
post #2 of 19 Old 06-22-2015, 01:07 AM
ZombiePopper
If there's no markings then there's a good chance it won't matter. Some are a one-way only and some don't matter.
1 way is to slap it on and if you're not getting fuel then flip it over.
69Dodge Dart Swinger 5.9l mag swap
89YJ Wrangler 4.2
ZombiePopper is offline
post #3 of 19 Old 06-22-2015, 03:03 AM
Drednot
Actually, it does matter.
While it will work either way, it is designed to flow from the outside of the filter to the inside just like an oil filter.
It gives a functionally larger surface area to catch the sediment and last longer before clogging up.
Is one side bigger than the other? That's usually the inlet.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #4 of 19 Old 06-22-2015, 07:35 AM
mike134
I agree with drednot. And I think it is supposed to be marked. Align the crimping on the can in the same direction as the arrow above.
Glad you're changing your filter! this can really save you a lot of fuel pump trouble...
mike134 is offline
post #5 of 19 Old 06-23-2015, 05:37 AM Thread Starter
TestBedOne
Thanks guys! I took it back off and sure enough I had it facing the wrong way. But now I know how to put it on if its not labeled by checking the nozzle sizes. Now I should be getting nicely filtered fuel into the 4.0L, I need that baby to last!
Thank you!
-Innocent Bystander
post #6 of 19 Old 06-23-2015, 07:13 AM
mike134
awesome, thanks for posting the solution!
That old oil filter is pretty disgusting on the outside. I wonder how it looks inside. you might be able to feel the difference at high rpm!
mike134 is offline
post #7 of 19 Old 06-23-2015, 07:19 AM Thread Starter
TestBedOne
Originally Posted by mike134
awesome, thanks for posting the solution! That old oil filter is pretty disgusting on the outside. I wonder how it looks inside. you might be able to feel the difference at high rpm!
I still have the old filter kicking around. Want me to open it up and see?
-Innocent Bystander
post #8 of 19 Old 06-23-2015, 10:45 AM
mike134
hah. I'd be very curious! The original filter and hoses were not meant for ethanol. I wonder if that has any effect. I bet the hoses were eaten away and you'll find a lot of hose material in there.
mike134 is offline
post #9 of 19 Old 06-23-2015, 12:04 PM
Drednot
Yes. I always cut my filters open to see what they caught.
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #10 of 19 Old 06-23-2015, 02:56 PM
ZombiePopper
Well,
Ya learn something new everyday!
I've used unmarked universal fuel filters (same size inlet/outlet) thrown on anyway and never had an issue/problem before,
Go figure.
89YJ Wrangler 4.2
post #11 of 19 Old 06-23-2015, 07:57 PM
JrTjK
1978 FSJ Wagoneer
good post. Are you sure the filter wasn't marked? I've yet to see a Crown one that didn't say Inlet or Outlet on them by the nozzles, faint, but usually there.
JrTjK is offline
post #12 of 19 Old 06-23-2015, 08:21 PM
mike134
I thought the crowns were black... this one is blue... was it form a reputable source?
mike134 is offline
post #13 of 19 Old 06-23-2015, 08:50 PM
reeveskd
This is like science class: I would also be VERY interested to see the inside of a recently-cut-open filter. The more the better; it's like some kinda X-Files thing. So kool.
reeveskd is offline
post #14 of 19 Old 06-24-2015, 01:01 AM
DirtKar
I pledge allegiance.
DirtKar's Avatar
It's kinda hard to tell from the pic, is that your frame that looks like it is rusted away to nothing?
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #15 of 19 Old 06-24-2015, 03:16 AM
Drednot
Couple other cut a ways
90 XJ fuel pump
Pump rollers
89 trooper injector
74 CJ coil
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
