Fuel Filter - JeepForum.com
post #1 of 2 Old 08-08-2011, 08:53 AM Thread Starter
stanglx2002
Fuel Filter
The PO capped off the return line and used a standard one inlet and one outlet.
I want to replace the fuel filter and wondered if you guys have the part number to filter you guys use in this same situation.
stanglx2002 is offline
post #2 of 2 Old 08-08-2011, 09:28 AM
sacrifice
Any autozone/advance will have a few in stock, just give them your vehicle specs. Be sure to run one outlet to the carb and one to recirculation.
granny shifting not double clutchin like I should
'89 YJ Build Thread:
WhyJayPA's '88 Build: http://www.jeepforum.com/forum/f22/mean-green-build-college-budget-1164650/
sacrifice is offline
1990 4.2 new carb, fuel filter, fuel pump barely runs, help. litz YJ Wrangler Technical Forum 18 05-17-2017 10:04 AM
No fuel to filter...fuel pump or relay?? jason280 YJ Wrangler Technical Forum 10 03-25-2011 07:10 PM
Surging and poor performance.....fuel filter? fuel pump? lwoods TJ Wrangler Technical Forum 17 09-09-2009 07:10 PM
Fuel filter replacement - How do I depressurize fuel system? Rproject YJ Wrangler Technical Forum 13 11-23-2008 08:34 AM
fuel pump?fuel filter?relay? garoughrider YJ Wrangler Technical Forum 2 02-26-2008 05:23 AM
