Fuel filling assemby after 2in BL - JeepForum.com
post #1 of 2 Old 02-24-2010, 06:54 AM Thread Starter
YjMick
After installing my body lift I found out that my fuel filler hose is not long enough for the filler neck to bolt to the body. Has anyone else had this problem? Also the hose clamp that connects the hose to the tank is facing upward so it seems impossible to loosen it.
YjMick is offline
post #2 of 2 Old 02-24-2010, 07:23 AM
jbolty
jbolty's Avatar
If it's in good shape cut it and extend with a piece of copper or stainless pipe of the proper size.
I ran the extension for a while after I did the side filler mod then was able to track down some hose at ace hardware.
jbolty is offline
fuel filler , gas tank hose
getting fuel...getting spark...TBI is filling...tried starter fluid... rain-gler YJ Wrangler Technical Forum 11 08-05-2009 08:42 AM
Fuel filling problems! jdragger TJ Wrangler Technical Forum 1 12-02-2007 07:41 PM
Filling Fuel Tank Problems indyguy9791 YJ Wrangler Technical Forum 14 08-23-2007 05:31 PM
Slow fuel filling. Wolffman TJ Wrangler Technical Forum 2 11-26-2006 10:59 AM
97 TJ fuel filling problem mikeumkc TJ Wrangler Technical Forum 15 10-11-2005 05:16 PM
