Fuel filler - JeepForum.com
post #1 of 3 Old 04-12-2013, 12:01 PM Thread Starter
vdubbles24
Fuel filler
Kinda in a bind. Need some help. Fuel filler hose just broke, gonna call and have some fuel line delivered here at work. What's the size of the hose. It was dry rotted hoped it would've lasted longer.
vdubbles24 is offline
post #2 of 3 Old 04-12-2013, 12:21 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Look here: http://www.mtscompany.com/hose.htm
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #3 of 3 Old 04-12-2013, 12:40 PM
timatoe
timatoe's Avatar
Order it from MST, the filler side and tank side are different sizes.
That being said when I moved the filler to the TJ location on the driver side I used clear poly hose 1" ID and heated one end (I think the tank side) with a heat gun so it would stretch around the neck opening. I don't think you'll get regular fuel line with the nylon inner braiding to stretch that way though.
timatoe is offline
