fuel cell with oem fuel pump? - JeepForum.com
post #1 of 6 Old 07-27-2013, 10:14 PM Thread Starter
drewyj
are there any fuel cells that use the stock
fuel pump assembly?
drewyj is offline
post #2 of 6 Old 07-27-2013, 10:19 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
http://www.genright.com/ProductInfo....0#.UfSbeFWnapg
Fits behind the rear seat and uses the stock module.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #3 of 6 Old 07-27-2013, 10:21 PM Thread Starter
drewyj
thanks! ive been looking for a while, seems jegs and 4wp dont have any!
drewyj is offline
post #4 of 6 Old 07-28-2013, 07:27 AM
TSEJEEPERS
You can also use a RCI 2161 fuel cell, cut a hole in it and use your stock pump and sending unit.
This cell fits nicely behind your rear seat.
The only problem is the pump does not sit on the bottom of the cell, so you can not access all the fuel.
I fixed it by extending the tubes on the sending unit so that the sock sits on the bottom of the cell.
Do a search there are alot of writeups on the forum and on the web.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #5 of 6 Old 08-01-2013, 09:37 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
What he said ^^^
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #6 of 6 Old 08-01-2013, 10:39 AM
kloppk
Another option is to add an external fuel pump to the RCI 2161.
That's what I did on my YJ. The pump was only about $60 from Summit Racing.
Easier than hacking a hole in the tank, tapping holes, etc.
The 2161's fuel sender also works with the YJ fuel gauge. Just hook the sensor and ground wire up. Done.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
