Quantcast Fuel Bypass Regulator vs. Replacement Fuel Pump - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Fuel Bypass Regulator vs. Replacement Fuel Pump
Old 06-26-2009, 10:52 AM   #1
gsmith795
So I've been trying to find a solution to my fuel rail problem for the past couple of weeks with no success. My problem is that I have a 4.0 out of a ZJ which had the regulated fuel pump, so my fuel rail only has a delivery port. My stock set-up was the unregulated pump feeding a fuel rail with the delivery and return ports.
I have been looking everywhere for the fuel rail I need but no one has them (or they have working engines and dont want to remove the fuel rails, which I don't blame them for). A friend of mine recommended using a bypass regulator, in this case a Trick Flow Specialties (http://www.summitracing.com/parts/TFS-27001/?image=large) to send the required PSI to the fuel rail and return the rest to my tank, which would be a fairly easy install (I think) seeing as how I already have the delivery and return lines running up my frame to the firewall.
Should I go ahead and do this or would it be better to swap out the fuel pump for a regulated one? I'd rather not have to drop the fuel tank or attempt to find the right fuel pump for my situation...
2004 Mazda RX8
1992 YJ Rebuild Project
http://www.tgjeep.blogspot.com
gsmith795 is offline   Reply With Quote
Old 06-26-2009, 02:43 PM   #2
gsmith795
bumpity bump...
anyone have any opinions?
will this definitely work if i'm willing to spend the money on it?
2004 Mazda RX8
Old 06-26-2009, 04:25 PM   #3
$300xjwith250k
my motor is out of a zj just use a stock rail from a yj or xj
$300xjwith250k is offline   Reply With Quote
Old 06-27-2009, 06:35 PM   #4
gsmith795
Yeah that was my first choice but it's a little hard to find a fuel rail (read my original post), especially one for an early 90's 4.0. I've been looking for the past two weeks and I haven't found one yet.
2004 Mazda RX8
Glock Forum
