Quantcast front wheels pidgen toed - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > front wheels pidgen toed
Old 02-07-2006, 09:23 PM   #1
toates89
1989 XJ Cherokee
i have an 89 with 31's no lift and from the front of the car you can tell that the front wheels are slanted a slight bit. the top of the tire are slightly pointed inward.
any suggestions about what was the cause and how it can be fixed?
toates89 is offline   Reply With Quote
Old 02-07-2006, 09:28 PM   #2
crazymon01
bent knuckle??? if u jack the tire off the ground can u wiggle it top to bottom? possible bad u-joint
I6
ARB snorkle
307 -> 411 gear swap
lock rite locker on the dana 35
33 x 12.50 Mickey Thompson radial MTZ
4.5" Rubicon Express heavy duty Suspension Lift
currie boomerang shackles
8,000 lbs. Winch
bikini top
tonneau cover
pictures?? http://www.cardomain.com/id/ironm98
crazymon01@aol.com
crazymon01 is offline   Reply With Quote
Old 02-07-2006, 09:30 PM   #3
paintguy
how are the tread on the tires wearing? how does it steer?
paintguy is offline   Reply With Quote
Old 02-07-2006, 09:35 PM   #4
toates89
1989 XJ Cherokee
they are brand new tires so i dont know and it doesnt drift
Old 02-07-2006, 09:36 PM   #5
toates89
1989 XJ Cherokee
the tires dontn wiggle and is it likely that both knuckles bent?
Old 02-07-2006, 09:39 PM   #6
jipjip
it may be just an illusion. you have a fixed front axle, and for both sides to bend in at the top, is highly unlikely. i wouldn't worry about it.
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,33" trxus m/t's.
1" bl,and ramsey winch on their way.
jipjip is offline   Reply With Quote
Old 02-07-2006, 09:40 PM   #7
paintguy
Mine has the same type of camber (I believe it is positive camber when the top of the tire is in) -- just watch your tire wear and I wouldn't worry about it if it seems to drive fine -- it may be more noticeable now that you have 31's on it?
Old 02-07-2006, 09:52 PM   #8
toates89
1989 XJ Cherokee
i bought it with 31's
Old 02-08-2006, 02:17 PM   #9
Yule16MET
If its the top of the tire pointed inwards then Its probly ball joints but if the tires are pointed forwards then your steering lincage between the knuckles is probly bent.
I dream of the jeep, drive the chevy and roush pays for it all
1990 YJ lerado,Soa,2.5R.E.springs,8.8,4.88'sPSC trail cage&rocker nockers w/sliderbars,home made bumpers, 35"boggers,sye, tomwoodsds, revolvers, red & yellow optima, bushwackers,corbeua ss seats,mc2100,juicebox, 3core rad., b&mshifter and highlift,5point harnesses,wheel spacers,9000lb mile marker,ssdash kit,no sway bar, no trackbar, walmart lights,clinometer, XJ passenger shaft, axle tube seals, M.O.R.E track bar
And a Monster Yellow CJ5
40x17's 12"lift full cage
Blackjeepclub #16
Armyjeepclub #16-#1
yellowjeepclub #BIG16
Yule16MET is offline   Reply With Quote
Old 02-08-2006, 03:59 PM   #10
tobias94yj
Hillbilly Member
tobias94yj's Avatar
Go get a front end alignment and they will be able to tell you if have a camber problem
To view the NEW Jeep Encyclopedia click here!!!
tobias94yj is offline   Reply With Quote
Glock Forum
