front wheel trying to fall off - JeepForum.com
post #1 of 12 Old 10-18-2007, 09:14 AM Thread Starter
ionakana
Grand Poobah
ionakana's Avatar
Last saturday I was driving my heep down the expressway when it started having a bad vibe in the front end. When I pulled off the road I could hear a popping noise. I made it to where I was going and we figured it was a bad wheel bearing. I limped it home and to my horror discovered the wheel was ready to fall off when I made it there, all the lugs where coming off as well as a broken wheel stud. I put a new hub and rotor on because it destroyed my rotor. Put it all back together and there still feels like the wheel is a little loose. I took it for a drive around the block then jacked it up and the wheel is really loose. Took everything back apart and checked it, everything seems fine. Put it all back together again but the wheel still feels loose, kinda like a bad ball joint but it's not the ball joint moving. Could it be the axle bearings? It's not the axle, it's tight. I don't know what else to look for.
Psalm 14:1
Live in Georgia? click here-->
ionakana is offline
post #2 of 12 Old 10-18-2007, 09:29 AM
muddy93
1987 FSJ Wagoneer
if the wheel is moving, it would be because of one of two things, ball joints, or wheel bearing(unit bearing).
did you get the nut on the end of the stub shaft tight enough(torqued to proper specs.)? if that nut is not tight enough, the unit bearing will seperate.
I can't remember the correct torque for the stub shaft nut at the moment, but I'll look and see if I can find it.
muddy93 is offline
post #3 of 12 Old 10-18-2007, 09:59 AM Thread Starter
ionakana
Grand Poobah
ionakana's Avatar
yes, I tightened the nut on the axle shaft with a impact wrench, it's on there!
Psalm 14:1
ionakana is offline
post #4 of 12 Old 10-18-2007, 11:07 AM
mp3coupe
mp3coupe's Avatar
Jack up the problem side under the leaf spring/axle.
Once you get the wheel off the ground and the jeep is secured.
Kneel down infront of the tire and grab a hold of the tire at 12 oclock and 6 o'clock. Now wiggle the tire back and worth, nothing crazy be easy with it. It also helps to have a helper watching for play. If its tight grab the tire at 9 o'clock and 3 o'clock and repeat. If you have play you'll be able to spot it.
mp3coupe is offline
post #5 of 12 Old 10-18-2007, 11:29 AM
EABiker
If your lugs nuts were that loose, all that wobbling may have rounded out the lug holes on the wheels. Pull the wheel and check those holes!
EABiker is offline
post #6 of 12 Old 10-18-2007, 11:45 AM Thread Starter
ionakana
Grand Poobah
ionakana's Avatar
yes, it rounded out the holes, I put the spare on until my new wheel comes in. It's not the ball joints. he only other thing I can think of is I got a bad bearing in the new hub I just installed.
Psalm 14:1
ionakana is offline
post #7 of 12 Old 10-18-2007, 12:37 PM
goatchze
Have you tried rotating the tires and see if the problem moves?
I had a problem with a worn bearing/hub that had a vibration which backed out the lugs. Wheel actually came off the Jeep, but fortunately I was crawling through the pasture (In high school, with a date! Talk about looking like a stud muffin....)
EDIT:
I put the spare on...
Sorry, missed that part.
"Hey, hold my beer and watch this...I can make that"
goatchze is offline
post #8 of 12 Old 10-18-2007, 05:46 PM
dave_dj1
the single biggest cause of unit bearing failure is improper torque! 175 ft lbs is spec on wranglers. PLEASE do NOT just impact gun them on!!!!!!!!
Wheel it like ya stole it!
dave_dj1 is offline
post #9 of 12 Old 10-19-2007, 06:24 AM Thread Starter
ionakana
Grand Poobah
ionakana's Avatar
I was told by the Jeep/Dodge dealer to torque it at 325 lbs. They also said they just use a impact gun to do it. I used my friends small gun to do it, it's about 350lbs. I guess I know what the problem is now.
Psalm 14:1
ionakana is offline
post #10 of 12 Old 10-19-2007, 06:40 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
HOLY CRAP MAN!!!!!!!!!!!! 325lbs??????????????
Some one was BSin you. 175ft lbs.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #11 of 12 Old 10-19-2007, 08:34 AM
bamato
bamato's Avatar
BA-JESUS!!!!! 325 ft/lbs??!!! My god, there's a perfect example as to why you shouldn't take your rig to a dealer.... EVER!!!
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline
post #12 of 12 Old 10-19-2007, 09:32 AM Thread Starter
ionakana
Grand Poobah
ionakana's Avatar
I couldn't find my Jeep book and I was at the dealer looking at trucks so I asked. Maybe I'll call up there and tell them they have a ******* working for them or maybe I'm the ******* for listening to him.
Psalm 14:1
ionakana is offline
How to remove front wheel bearings/hub from front axle? Tshark299 YJ Wrangler Technical Forum 10 09-17-2010 07:55 PM
LJ's wobble but they don't fall down; or, my front end DME TJ Wrangler Technical Forum 8 05-22-2009 12:23 PM
Is My Steering Wheel Gonna Fall Off? Please Help! pshirek YJ Wrangler Technical Forum 14 05-07-2008 07:57 AM
Front Wheel Skip at full wheel lock?? EnigmaMan TJ Wrangler Technical Forum 3 09-26-2007 10:43 PM
Where did this fall off???? mike481 TJ Wrangler Technical Forum 32 09-23-2007 02:57 PM
