#1 | |
Front Wheel Toed Out Bad
Is this just an alignment or something I can adjust myself.
thanks
#2 |
ISO 9001 Compliant
there is nothing adjustable in the front end for an alignment, except the toe in. Easy to do.
There was a great write up posted just recently but I can't find it right now. Maybe someone else will link to it. In any case it's about a 15 minute job, including looking for tools. Actually caster can be adjusted too, with shims, but no alignment shop would do that. Also, check the ball joints and tie rod ends. If the wheels are suddenly out of whack thats a good place to look and the parts are not very expensive.
. . "The right to be heard does not necessarily include the right to be taken seriously." —Hubert Humphrey . If you live within wheeling distance of San Diego county, click here |
#3 |
#4 |
ISO 9001 Compliant
Not the one I was thinking of but that is good info too.
key tips Only jack enough so the tires clear the ground support under the axle, rather than the frame. be on level ground. the width is not important, just the front the back difference. measure as close to the verticla center line as possible.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
