Quantcast front wheel problems (u joint, ball joint etc) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > front wheel problems (u joint, ball joint etc)
Old 06-05-2005, 04:40 PM   #1
ohhpe
Hey i was checkin my wheel/axle to make sure everythign was good.
First off there is grease coming out the top of the ball joint and underneath it is covered in grease... whats with that?
When i started shaking things.. if i grab the Rotor disc by itself it moves a LOT. I can wigggle it back and forth, up and down, the brake caliper moves aroudn with it.. is that normal?
looking behing the rotor the u joint seems to twitch a tiny bit as well..
any suggestions?
95 yj 6" lift, 33" truxs mts
ohhpe is offline   Reply With Quote
Glock Forum
