front wheel bearing - JeepForum.com
post #1 of 20 Old 12-22-2009, 09:21 PM Thread Starter
cpundsack
1987 YJ Wrangler
front wheel bearing
So I bought some new tires today (31X10.5X15 BF Goodrich all terrain t/a) and I was not able to get an alignment because my front right wheel bearing is apparently bad. I was able to wobble the tire with my hands while the car was lifted. My question is, where is the best place (cheapest) to buy a replacement and is their a write-up anywhere? I'm searching, but haven't found too much as of yet, any help appreciated!
cpundsack is offline
post #2 of 20 Old 12-22-2009, 09:28 PM
TSEJEEPERS
Do a search for unit bearing.
Though if I remember right your year of Jeep can replace just the bearings, but I have not heard of anyone being able to do it.
You can buy the unit bearing pretty much anywhere. Looking at under $200.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 20 Old 12-22-2009, 09:30 PM
4.7stroker
I believe the best place to buy the unitbearing would be Napa, they seem to have the best quality/price. For the how to replace it I would refer to your Haynes/Chilton manual. The hard part will be getting the unit bearing to let go of the housing. I have found that a sharp chisel in between the bearing and hub helps to get things moving. I used an impact chisel and it popped right out, down here in the desert we do not have to contend with rust so things are much easier. PB Blaster will be your friend.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #4 of 20 Old 12-22-2009, 09:31 PM Thread Starter
cpundsack
1987 YJ Wrangler
thanks guys!
post #5 of 20 Old 12-22-2009, 09:36 PM
rivalarrival
Stormaggedon
rivalarrival's Avatar
Wheel bearing assembly is pretty straightforward to replace. Any decent parts store will have them. I recommend Timken bearings.
Look at the first post in this thread:
http://www.jeepforum.com/forum/f140/...sembly-377533/
The hub assembly should be just about the same on your vehicle.
If the hub doesn't pop right out, check the trick in my signature. In some areas, they will rust-weld themselves into the steering knuckle.
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself. --Thomas Paine
We work together every damn day. --Jon Stewart
Any gas can be a knockout gas, when you wrap a steel cylinder around it and beat someone with it.
Low Output 4 Cylinder Jeep Club member #188
rivalarrival is offline
post #6 of 20 Old 12-22-2009, 09:38 PM
TSEJEEPERS
Heck they are cheaper than I thought.
AutoZone.com | Vehicle Selection | Year
post #7 of 20 Old 12-22-2009, 09:40 PM Thread Starter
cpundsack
1987 YJ Wrangler
Nice! only $100, the stealer was quoting over $200 plus labor! figured I should research it a little . . .
post #8 of 20 Old 12-22-2009, 09:42 PM
rivalarrival
Stormaggedon
Dwayne
Check out the linked photo in my signature. You can wedge the hub assembly against the axle tube, and use the steering to pop it out. I was a bit skeptical at the idea - I had utterly destroyed the first hub with a chisel and a couple hours of banging on it before I found that method. The second hub literally popped out of the knuckle.
post #9 of 20 Old 12-22-2009, 09:56 PM Thread Starter
cpundsack
1987 YJ Wrangler
Thanks, I will give it a try and report back!
post #10 of 20 Old 12-23-2009, 08:08 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
I used that same method years back, except with a deep socket. Worked better than I could have imagined!
I installed a $70 NTP unit from Advance and haven't had a problem with it since... but now I see rockauto.com has the Timkin for only $87.79.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #11 of 20 Old 12-23-2009, 08:15 AM Thread Starter
cpundsack
1987 YJ Wrangler
Hmmm, Thats a good price! that site is sooo unfriendly to search! can you link me to that timkin?
post #12 of 20 Old 12-23-2009, 08:30 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
Yeah, that site took some getting used to for me... but I've got it mostly figured out now. I'm still not sure how to directly link to one of their parts though.
The part number you want is 513107. The easiest way to find it might be to click on the "Part Number Search" tab at the top, then enter that number and select "TIMKIN" as the manufacturer.
If you go through the long way of selecting your year, make, model, engine, etc., it's located under "Brake/Wheel Hub", then "Axle Bearing and Hub Assembly".
post #13 of 20 Old 12-23-2009, 08:32 AM Thread Starter
cpundsack
1987 YJ Wrangler
Found it! It is still close to $100 shipped and will take quite a while to reach me, so think I will go with the $70 Napa part so I can get this done over the weekend, and not sacrifice my new tires
post #14 of 20 Old 12-23-2009, 10:22 AM
540i
Look on ebay, I bought a pair for $95 shipped I think, made in USA, two for the price of one at autozone
540i is offline
post #15 of 20 Old 12-23-2009, 06:03 PM Thread Starter
cpundsack
1987 YJ Wrangler
why is every bolt on a jeep impossible to get off, damn! stuck on both the caliper bolts right now . . . letting the pb blaster soak in . . .
Front Wheel Hub/Bearing ? SuperWade2 TJ Wrangler Technical Forum 17 04-30-2009 06:28 PM
right front wheel bearing gone steve62 TJ Wrangler Technical Forum 3 03-08-2009 02:55 PM
Front wheel bearing? Tj4rocks TJ Wrangler Technical Forum 1 04-24-2006 07:44 PM
Front Wheel Bearing help vmkwrangler YJ Wrangler Technical Forum 14 02-06-2005 07:17 AM
Front Wheel Bearing Resqfiremedic YJ Wrangler Technical Forum 4 12-23-2002 01:25 PM
