Front weel bearings - JeepForum.com
post #1 of 9 Old 12-01-2001, 07:49 AM Thread Starter
glm 87 wrangler
Front weel bearings
My haynes book says my front wheel bearings
need special tools to work on them.So i am guessing they are pressed in. Is this so?
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #2 of 9 Old 12-01-2001, 11:27 AM
osburn
osburn's Avatar
They're not serviceable. The hub, spindle and bearings are all one sealed unit. We tried to service a set once but they failed very soon afterwards. Your best bet is to simply replace them. If they're not totally wasted, carry the old ones as trail spares.
Matt Osburn
Score 1032
osburn is offline
post #3 of 9 Old 12-01-2001, 01:10 PM Thread Starter
glm 87 wrangler
Well off to the shop i go. Will take it in and have done my front right wheel is starting to have a little hum.Not that bad but dont want to take a chance.Thanks,Gary
post #4 of 9 Old 12-01-2001, 01:40 PM
I-4
I-4's Avatar
DO GO TO THE SHOP IF YOU ARE MECHANICALLY INCLINED!!!!!!!!!!!!!it took me and a buddy 45 minutes to do this surgery that included putting the dust shield for the rotor on backwards and pulling back apart!the only thing that will really help is let the three bolts get plenty of penetrating oil and a slide hammer will make very short work of a very easy project.it is very easy to do...
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
post #5 of 9 Old 12-01-2001, 06:47 PM
osburn
osburn's Avatar
I agree, it's an easy job if you have the tools. The tools you need are exactly what you'd need if you were on the trail and broke an axle u-joint or a shaft. So they're a wise investment.
Matt Osburn
Score 1032
osburn is offline
post #6 of 9 Old 12-02-2001, 06:39 AM Thread Starter
glm 87 wrangler
Well i have all the tools so I guess they are not pressed into the hub.Just pop the whole assebly out and put the new in?? If thats the case I have done them on cars before I know its a diffrent set up but if the bearings are
one unit I can do it i was just worried they may be pressed in.I do have a slide hammer.
Ill read a little more about it.Jeeps do differ from cars.But im sure I can handle it.
Thanks again,Gary
post #7 of 9 Old 12-02-2001, 01:07 PM
osburn
osburn's Avatar
Yup, you pull the whole assembly. Then put in a whole new assembly. Keep the old for spare.
Matt Osburn
Score 1032
osburn is offline
post #8 of 9 Old 12-02-2001, 01:26 PM
evilpsych
evilpsych's Avatar
how much an assembly cost ususally?
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #9 of 9 Old 12-02-2001, 06:15 PM
osburn
osburn's Avatar
Never bought one so really I'm not sure. I've only known of two of these to fail among my friends. One on a YJ (he had an old spare) and one XJ. The one on the XJ is the one we tried to service but it didn't work. He bought a new one but I never did ask what it costed. If I had to guess, $30 used $75 new. I wouldn't be entirely surprised if it was double that, but that'd be worst case I'd hope.
Matt Osburn
Score 1032
osburn is offline
Front hub bearings KC2OTE YJ Wrangler Technical Forum 5 05-06-2012 07:34 AM
How to remove front wheel bearings/hub from front axle? Tshark299 YJ Wrangler Technical Forum 10 09-17-2010 07:55 PM
rebuild weel hubs? aaronc88 YJ Wrangler Technical Forum 1 08-21-2008 09:01 PM
Hub Front Bearings DaSham58 YJ Wrangler Technical Forum 3 03-06-2008 07:31 PM
Weel fly's off while driving!!! bowenjeep YJ Wrangler Technical Forum 28 08-17-2006 06:12 PM
