Front Ujoint replace - skid plate remove necessary? - JeepForum.com
post #1 of 3 Old 03-07-2007, 09:10 AM Thread Starter
FlatsCrawler
FlatsCrawler's Avatar
I forget since the last time I replaced my front DS U-joint...do you need to remove the skidplate
I know that you can detach the DSS from the TC yoke easily enuough w/o removing skid plate, can I simply pull the front ds out of the front diff and work on replacing the u-joint off the vehicle?
Replaced it a year ago but there is some play and with the RE XD 4.5" lift I wanted to put a beefier joint in to fit the rest of the lift, cv, sye, etc.
Thanks
Flats Crawler
93 4.0L 4.5 RE XD, SYE, CV DS, Nitros, SS BL, 33 Baja Claws, MT ClassicLocks 15X10
/l , [____],
[___lL---[]lllllll[]-
()_) ()_)---o-)_)
FlatsCrawler is offline
post #2 of 3 Old 03-07-2007, 09:31 AM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Easy to do, don't need to drop the skid.
5/32 bolt or 8MM both fit just about perfect. both ends have the bolt/strap combo.
- Ernie
Richmond88yj is offline
post #3 of 3 Old 03-07-2007, 09:36 AM Thread Starter
FlatsCrawler
Thanks bud
Flats Crawler
/l , [____],
()_) ()_)---o-)_)
How in the $#!%# do you remove the skid plate for a new cat? mrbriteside1465 YJ Wrangler Technical Forum 19 08-13-2009 08:00 PM
Can I remove tranny skid plate? Gabagool YJ Wrangler Technical Forum 7 06-06-2009 09:31 PM
Do I need to remove the skid plate to do this? None TJ Wrangler Technical Forum 6 01-05-2007 08:12 PM
HELP! How to remove starter with skid plate???/ ping65810 TJ Wrangler Technical Forum 9 08-19-2006 09:01 PM
Replace cat w/o removing skid plate bryris YJ Wrangler Technical Forum 12 07-21-2006 07:34 PM
