Front Trans Seal - JeepForum.com
post #1 of 2 Old 04-12-2007, 10:49 AM Thread Starter
Jim Piszar
Jim Piszar's Avatar
Front Trans Seal
I will be putting my new engine in this weekend and was wondering if I should replace the front Transmission seal as long as the engine was out. It doesn't seam to be leaking. Is it difficult to change the front seal? The torque converter is still in the transmission.
jim
Jim Piszar is offline
post #2 of 2 Old 04-12-2007, 11:15 AM
the dit
I should not be hard, but in the past I never bothered. If you do replace it make sure to get the converter fully seated back in, it can be tricky.
89 Yj Sahara, 4.2L, 31X10.5 MT's, Weber carb, nuttered, Mustang Seats, 6" Xenon flares
2004 Dodge Ram 1500 4x4 Hemi
83 Mustang vert
the dit is offline
Seal driver for front axle seal, disconnect side sequel YJ Wrangler Technical Forum 24 01-24-2010 06:05 PM
Front diff seal leak out the back. how do i fix the seal?? Mitchin TJ Wrangler Technical Forum 10 01-23-2010 09:14 AM
Help - Trans Pan Seal 1991zx6 TJ Wrangler Technical Forum 12 04-03-2009 03:23 PM
trans shifter seal????? sam.b. YJ Wrangler Technical Forum 13 10-25-2008 12:03 PM
Rear trans oil seal, who's replaced it??? Why J? YJ Wrangler Technical Forum 6 05-05-2007 10:43 AM
