Front track/sway bar removal pics(repetitive/redundant questions merged here as well) - Page 7 - JeepForum.com
 13Likes
post #91 of 1435 Old 02-26-2009, 09:57 AM
sebastian22
Let me make sure I understand...you took off the trac bar and tried to see if it made a difference in the flex with the swaybar still connected?
RC springs are pretty flexy...
95 Black YJ
sebastian22 is offline
post #92 of 1435 Old 02-26-2009, 09:59 AM
RockShoxTora
I doubt it's stiffness.
Despite popular belief, I run RC AAL all around and get pretty good flex for 1.5 inches of lift and that's about as stiff as they come.
I removed the trac bad and I have my 31s crammed up inside of the fenders at full flex (I've already done some fender damage haha).
It may just be a myth, though I think it just allows the axle to move in a more fluid motion without the variable of a metal rob limiting it's movement in any direction.
I'm not sure if I'm correct.
Maybe someone with more knowledge can chime in.
-Brian
P.S. - Full flex with AALs. Tracbar (front) and sway bar removed.
1995 YJ
-3.5" Black Diamond Suspension Lift, Skyjacker Hydro 7000s
-1.25" Body Lift
-Trail-Gear Bumper and Tire Swing-Out
-31" BFG M/Ts KM
Square Headlights Member #751
RockShoxTora is offline
post #93 of 1435 Old 02-26-2009, 10:02 AM
RockShoxTora
While I'm at it,
Sorry for the hi-jack, but would anyone here know how to prevent my tires from bending up my fenders (the sheetmetal part) without hurting the uptravel of the axle (i.e., extra long bumpstops inhibiting up axle movement).
-Brian
1995 YJ
-1.25" Body Lift
-31" BFG M/Ts KM
post #94 of 1435 Old 02-26-2009, 10:15 AM
RikRotorhead
I removed mine and it made a huge difference. I'm not sure that a floor jack test is a real test.
Take it out and play with it. Bend it, flex it, and abuse it.
You can always put it back on if you don't notice a difference.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #95 of 1435 Old 02-26-2009, 11:09 AM
fyrdriver
1983 CJ7
Yeah I tried it both with the sway connected and without just for comparison purposes.
I was also unsure about the floor jack test. It can't simulate the type of flex in your pics.
I guess I will have to go try it out now. Thanks for the input.
Firefighters Jeep Club
fyrdriver is offline
post #96 of 1435 Old 02-26-2009, 11:45 AM
scrapinrocks
having the track bar on limits flex my almost 30% although you will not see any results with the sway bar still connected.
scrapinrocks is offline
post #97 of 1435 Old 02-26-2009, 11:48 AM
Goobersbro
How new are your spings are they broke in yet??
My marshmallow build
Goobersbro is offline
post #98 of 1435 Old 02-26-2009, 12:07 PM
fyrdriver
1983 CJ7
Thats kinda what I was getting at with my post. Alot of guys say they remove trac bars but leave the sway. To me(based on my little test) you have to remove both to see the results.
BTW my springs:They are about 1+ years old and been off road a number of times, they should be broken in by now.
post #99 of 1435 Old 02-26-2009, 12:11 PM
sebastian22
This is true. Most people who say remove the trac bars but keep the swaybar most of the time mean that you should keep the swaybar but install swaybar disconnects. That way you are sway free on the road, but then disconnect it when youre off road.
95 Black YJ
post #100 of 1435 Old 02-26-2009, 12:28 PM
Goobersbro
okay wasnt sure i know my rear springs just now have been finally broken in and there over two years old the PO never really wheeled it and then once i started wheeling i removed the rear track bar and they are a lot softer now havnt taken the front off yet but soon after i fix my ball joints buy a steering dampener fix my steering column and buy new tie rods i will be good to go
post #101 of 1435 Old 12-26-2009, 10:00 AM
YJ Newby
Maybe I am just being a dolt, but after extensive searching of the forums, I am unable to find a "Track Bar Removal for the Chronically Dumb" write-up. I keep reading all of the threads, and read all of the benefits [ride, flex, etc.] but every time I crawl under the Jeep to try this mod, I do not really know where to begin. Is there a "How-to" write-up anywhere on this forum that will walk me through the need-to-know's about removing track bars/sway bars? I am desperate to do this, but still nervous about going into it not fully armed with the do's and don'ts.
'90 YJ with a 2-3" Body Lift, but stock suspension.
Thank you for your input.
YJ Newby is offline
post #102 of 1435 Old 12-26-2009, 10:21 AM
Ptr
1992 J-Series Truck
Ptr is offline
post #103 of 1435 Old 12-26-2009, 10:23 AM
jeepdrvr101
Do you have a Chiltons manual? It has a decent explanation. However it says nothing about the sway bar.
89 YJ Islander, White with blue pearl custom paint, 4.2 Nuttered, Holley carb, Light bar W/4 Kc daylighters, 32x11.50r15, Unknown lift, kenwood sound, Rockford fosgate Amp x2, Kicker Amp(1)
A work in progress...
2006 Ram 1500 TRX4 5.7 HEMI All stock
jeepdrvr101 is offline
post #104 of 1435 Old 12-26-2009, 10:26 AM
jeepdrvr101
Originally Posted by Ptr View Post
Thats the old style, you need the new SUPER-SUPERSAWZALL, it rotates 180 in the center, and is shorter, lol
post #105 of 1435 Old 12-26-2009, 10:30 AM
YJ Newby
Thanks, I think!
YJ Newby is offline
bars , front track bar , jeep , remove , steering , sway bar , trac bar , trac-bar , track , track bar , trackbar , YJ
my track bar and sway bar removal w/pics YJ89jeepTX YJ Wrangler Technical Forum 1 03-27-2010 07:56 PM
Sway bar/Track removal...Right for me? SkullTripper YJ Wrangler Technical Forum 2 02-20-2010 09:40 AM
Sway and Track bar removal question - jeepsurf YJ Wrangler Technical Forum 7 01-14-2009 09:16 PM
sway bar and track bar removal petersyj95 YJ Wrangler Technical Forum 3 01-14-2009 06:41 PM
Track Bar and Sway bar removal Tim3852 YJ Wrangler Technical Forum 4 06-13-2006 01:47 PM
