Front track/sway bar removal pics(repetitive/redundant questions merged here as well) - Page 6 - JeepForum.com
 13Likes
post #76 of 1435 Old 10-26-2008, 11:20 AM
Jeeples
Jeeples's Avatar
Originally Posted by jay-h View Post
The track bar cost AMC money, so you can assume it's there for a reason (i.e. bad safety record for CJs).
Removing it will not improve your ride or significantly affect your flex, so I'm not sure why people want to take them off.
Sway bars are a different story. A disco is a good idea because they do interfere with flex, but at road speeds they add substantially to stability by controlling body roll, especially during emergency maneuvers.
Here's my mostly stock (shackles and 1" BL at the time) YJ without sway bars or track bars:
All four tires are solidly making contact with the ground. As you mentioned, there is a reason Chrysler/AMC put them on the YJ, however to say that they don't inhibit suspension travel is incorrect. Like Sleddin' mentioned, the leaf springs in YJ's offer more than enough lateral support to keep the axles centered under the Jeep.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is online now
post #77 of 1435 Old 10-26-2008, 12:06 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
You are looking at 2 problems here.
#1, are your lift shackles. They will drastically alter your caster angle, and at highway speeds you are going to have VERY light steering. The only way to solve this is to get an alignment to re-adjust the caster, or get rid of the lift shackles.
#2, you got rid of the sway bar. The sway bar helps keep the jeep's body from dipping left and right during cornering, or more importantly, evasive maneuvers. If you want to remove your sway bar for articulation, don't. Get disconnects.
I am running my jeep without tracbars and I have not noticed a single bit of difference with on-road manners. It is a highly debated subject on here and many on this forum have first hand experience that it will NOT make a difference. When I removed my track bars, I noticed an immediate increase in flexibility. When trying to flex, the track bar forces the axle outward. Since the leaf springs do not have any lateral movement, the system "binds" and doesn't flex.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #78 of 1435 Old 10-26-2008, 12:28 PM
Jeeples
Jeeples's Avatar
You will not be able to adjust the caster on a solid axle vehicle by simply doing an alignment. You will either need adjustable ball joints that will give you the ability to adjust caster or you will cut and re-weld your spring mounts to achieve to proper caster. As mentioned, your shackles will affect this measurement, the easiest way to fix this is a smaller set of shackles or factory height shackles.
OP,
I bet if you were to step down to some 1" lift shackles, you will notice a much better 'feel' to your steering, this is the maximum height that many people will recommend for shackles.
post #79 of 1435 Old 10-26-2008, 12:30 PM
Burnerman
Burnerman's Avatar
You can use shims to adjust it. I pulled out the 2.5* aluminum shims from my front spring plates. Use steel ones.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #80 of 1435 Old 10-26-2008, 12:31 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Thanks for the correction.
-Matt
White '94 YJ Sport
UltimatE is offline
post #81 of 1435 Old 10-26-2008, 12:32 PM
Jeeples
Jeeples's Avatar
True, but you can only go so far with shims, plus those of us that are lifted need to keep an eye on pinion angles.
post #82 of 1435 Old 10-26-2008, 01:26 PM
chadroc
What kind of shackles did you put on it?
chadroc is offline
post #83 of 1435 Old 10-26-2008, 01:38 PM
Alfons
If you know how far out the caster angle is, you can use steel shims for adjustment - these can be tacked onto the perch and will act like a re-positioned perch. It's true that your pinion angle will change and this will affect the drive shaft geometry. If you don't use 4wd on-road, smaller angles won't affect things much & if you do need to smooth things out, you can add a single or dual CV drive shaft to the front. The single CV shaft is only good with one larger angle such as you end up with on the rear axle, and sometimes you can luck out with the same configuration for the front. If you end up with both the pinion and the t-case angles of more than a few degrees, you can fix this by having a drive shaft made with two CV joints - one for each angle. Here's a picture of a front CV joint DS (only have a pic of one end).
The shaft shown in the above pictures was built from 2 XJ front drive shafts. It was re-tubed for added length, the second CV joint added to the pinion end, balanced, and then with 2 CV yokes, it was good to go.
Alfons is offline
post #84 of 1435 Old 10-26-2008, 02:26 PM
yjmoose
my vote is that your problems relate to your lift shackles, and not your lack of sway bars or track bars. I run 2 inch lift shackles, which are 4 inches longer than stock (tempoary poor mans lift as well) and also have issues like you describe that for some reason are MUCH worse when it is windy. I would remove the lift shackles if you can't handle it until you can porperly lift your jeep, or just deal with it until you can change the lift. On my jeep there is no "just cruising," if you arn't constantly paying attention, you will end up in the ditch. This is due to the lack of caster angle IMHO, I didn't have it when I first disconnected my sway bar, didn't have it when I removed the track bars, shackle lift went on and HOLY !@#$, it drives WAY different. I am the only one who drives it, never on the highway, mainly to and from work and I deal with it (unhappily) until I can afford the 2.5 inch lift springs I want.
Hope that Helps
yjmoose
yjmoose is offline
post #85 of 1435 Old 10-26-2008, 02:37 PM
BlackRhino
BlackRhino's Avatar
I have both trac bars removed and have noticed no change in street manners, even going as fast as 75 mph. I did leave the sway bar connected though. If your Jeep is having that much problems without trac bars, then there's something else that's wrong. Probably your shackles, which are 1 1/2 times as long as stock.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline
post #86 of 1435 Old 10-26-2008, 02:53 PM
bigsquat
Has any had any experince with an add a leaf. IT might stiffin it up cheeply untill u get the lift.I did this on a cj years ago and it help nthe street driving quit a bit . It did hower limit my wheel drop , which was bad offroad.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #87 of 1435 Old 10-26-2008, 05:33 PM
RikRotorhead
Originally Posted by Chris_1993_YJ View Post
I removed my sway bar and tracbar yesterday and now when I am cruising down the highway and hit a bump or turn my Jeep will sway side to side so bad that I have to slam on the brakes and slow down to get it to stop. My Jeep is pretty close to stock the only thing changed on the front is the shackles they are 1.5 inch straight lift shackles. I am wondering if anyone else had this problem as I do not want to put the Tracbar back on but I can't keep driving it the way it is. Any suggestions welcome thanks in advance.
Hey Chris.... I've seen your Jeep around town before. Nice rig.
If you want to bring it by sometime, we can try to narrow down the problem. How soon were you planning on doing the lift kit? That will probably remove the proplem anyway.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #88 of 1435 Old 10-26-2008, 07:12 PM
Chris
Guy with jeep
Chris's Avatar
I went through the whole front end today and I am convinced it is the cheap shackle lift the PO put on and decided to just reinstall my trac bar for the time being. RikRotorhead I take it you drive down Nutmeg alot or just seen me cruising around town, I am ready now to do the lift but my new home comes out of escrow this week in Wildomar so it will probably be a couple of weeks before I get the time and the new house has a three car garage making life alot easier.
To everyone else I agree that Chrysler put the trac bar on for a reason and I believe it helps in the stability of the Jeep but I don't believe it is a neccesary part when it comes to leaf springs.
Chris is offline
post #89 of 1435 Old 10-26-2008, 07:23 PM
pat8942
pat8942's Avatar
I don't have track bars and I drive my Jeep at highway speeds all the time with absolutely no issues.
The only difference I noticed after removing them was a better ride and more flex.
Originally Posted by jerryjeeper View Post
You may be able to drive safely without the sway bar (I have seen a lot of rigs w/o sway bars or with them disco) but the trac bar serves an important function "keeping the front axle centered under the Jeep" and should not be removed for street or highway use. If operating at speeds above 30 MPH, you are asking for a disaster.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #90 of 1435 Old 02-26-2009, 09:53 AM
fyrdriver
1983 CJ7
No not another should I remove tracbar question.
My post is about flex. History: Removed rear long ago. Just got around to removing front and it made no difference. The flex was the same in the front. I jacked up one side, left one side of the trac bar connected then realigned the trac bar and it was off only half of the bolt hole. Then I lowered the Jeep removed the sway bar and that easily gave me another inch of flex. Yes all my shackles were loose for testing.
So is the front trac bar debate a myth?
Are the RC springs so firm they just wont flex to take advantage of the removal?
Sorry not rying to find a new way to beat a dead horse, just trying to dial in my suspension/bumpstops. Opinions?
Firefighters Jeep Club
fyrdriver is offline
bars , front track bar , jeep , remove , steering , sway bar , trac bar , trac-bar , track , track bar , trackbar , YJ
my track bar and sway bar removal w/pics YJ89jeepTX YJ Wrangler Technical Forum 1 03-27-2010 07:56 PM
Sway bar/Track removal...Right for me? SkullTripper YJ Wrangler Technical Forum 2 02-20-2010 09:40 AM
Sway and Track bar removal question - jeepsurf YJ Wrangler Technical Forum 7 01-14-2009 09:16 PM
sway bar and track bar removal petersyj95 YJ Wrangler Technical Forum 3 01-14-2009 06:41 PM
Track Bar and Sway bar removal Tim3852 YJ Wrangler Technical Forum 4 06-13-2006 01:47 PM
