Front track/sway bar removal pics(repetitive/redundant questions merged here as well) - Page 4 - JeepForum.com
 13Likes
post #46 of 1435 Old 04-06-2007, 05:38 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Originally Posted by 72cj5er
Mine has extensions attached to the axle, about a 3" steel part that raises the lower bar mount, thing get loose all the time. Ill try and get a pic tommorow for clarity.
You mean like these POS?
Joe Dillard is offline
post #47 of 1435 Old 04-06-2007, 07:09 AM
jazzplr
Joe, I am honored to have your famous picture on my thread! I am very pleased with the results with the rear removed. I plan on doing the front this weekend. Is it normal to gain about an inch more lift with the bar removed? The back looks about an inch higher than the front now.
Hero's aren't born, they're cornered
jazzplr is offline
post #48 of 1435 Old 04-06-2007, 12:24 PM
95builtjeep
a trashcan is the best place for those tracbars. the only reason they were put in jeeps was because people forgot how to drive. cjs didn't have them at all. if you run the swaybar (which i would recommend for any street use), i would use quick disconnects. its worth the money.
95builtjeep is offline
post #49 of 1435 Old 10-09-2008, 01:07 PM
bigforeman500
1987 YJ Wrangler
tracbar help
hey guys, i got a 87 yj wrangler w/about 10" of lift, 39.5 tires, and i am missing the riser bracket that connects to the axle tube and the tracbar, any help with this would be great, the guy gave me a piece of steel to weld to the bracket on the axle tube, but i would like to it right, thanks
bigforeman500 is offline
post #50 of 1435 Old 10-09-2008, 01:50 PM
SimonTuffGuy
[I'm That Good]
SimonTuffGuy's Avatar
In the rear? It's been said, many, many of times that the rear track bar is useless.
SimonTuffGuy is offline
post #51 of 1435 Old 10-09-2008, 02:04 PM
jgillespie
X2. im not so sure how well the trac bar would hold up to that caliber of tires. not to mention the axles you must be running!
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
jgillespie is offline
post #52 of 1435 Old 10-09-2008, 03:23 PM
bigforeman500
1987 YJ Wrangler
tracbar help
it's on the front, the guy i got it from had a bunch of pieces missing from the tracbar and the sway bars, just trying to find the pieces to put it together, first jeep i've owned, been a old ford fan, but so far i am happy with the jeep
post #53 of 1435 Old 10-09-2008, 03:25 PM
ZeroGravity
Do you have any pictures?
Like of the Jeep itself =P
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #54 of 1435 Old 10-09-2008, 03:49 PM
jgillespie
in a leaf-sprung vehicle, or at least in the YJ, it is not even needed to have a trac bar. the springs themselves are all needed to keep the axle in place. if you want, repair it and put it back on. but if you want the maximize your spring articulation, then take it and the sway bar off.
X2 on the pictures of the jeep!
post #55 of 1435 Old 10-09-2008, 03:51 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Ditto 10char
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #56 of 1435 Old 10-09-2008, 06:23 PM
wildchild
Been runnin mine without the tracbar and the sway bar for a long time. But you better make sure your spring bushings are good and stiff or you will get kick in the rear usually when you shift gears goung down the road. I think when I do my axle swap I am going to make solid bushings for the rear springs.
wildchild is offline
post #57 of 1435 Old 10-09-2008, 06:24 PM
pasinbuy
I do not know on this one 10" lift and 39" tires. I think I would use track bars on the street for this one.
Let's see a pic of this monster.
pasinbuy is offline
post #58 of 1435 Old 10-09-2008, 06:27 PM
Jeffro06
Jeffro06's Avatar
Here's the profile pic...
but we need a bigger one.
Jeffro06 is offline
post #59 of 1435 Old 10-09-2008, 07:22 PM
sam.b.
wow 39s on a dana 30 and i assume a dana 35
you should video the rear end everywhere you go even if its to the local mcdonalds it would be cool to watch
btw i see no body lift im impressed
98 TJ Mild DD
90 YJ Sold
88 Samurai slowly being built for the rocks
<< Louisville Ky. based 4x4 club
sam.b. is offline
post #60 of 1435 Old 10-09-2008, 07:27 PM
provinT13
^^ your right same, check his profile, dana 30 and 35 locked, that will snap as soon as he thinks about hitting the locker switch, anyways, do a search, this topic has been covered quite a bit, and yes the rear trac bar is useless, but with that much lift i'd get a telescoping one if they make them, jks makes one for the front.
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
bars , front track bar , jeep , remove , steering , sway bar , trac bar , trac-bar , track , track bar , trackbar , YJ
my track bar and sway bar removal w/pics YJ89jeepTX YJ Wrangler Technical Forum 1 03-27-2010 07:56 PM
Sway bar/Track removal...Right for me? SkullTripper YJ Wrangler Technical Forum 2 02-20-2010 09:40 AM
Sway and Track bar removal question - jeepsurf YJ Wrangler Technical Forum 7 01-14-2009 09:16 PM
sway bar and track bar removal petersyj95 YJ Wrangler Technical Forum 3 01-14-2009 06:41 PM
Track Bar and Sway bar removal Tim3852 YJ Wrangler Technical Forum 4 06-13-2006 01:47 PM
