Front track/sway bar removal pics(repetitive/redundant questions merged here as well) - Page 3 - JeepForum.com
 13Likes
post #31 of 1435 Old 09-29-2006, 08:16 AM
dadstoy
I have all disconnected/removed. Its not a hot rod so I don't drive it like one so I don't really notice them gone. Flexing greatly improved. Scored 950 on a 30* RTI this past weekend. It also rides smoother on the road.
dadstoy is offline
post #32 of 1435 Old 09-29-2006, 10:38 AM
sauce90yj
sauce90yj's Avatar
I took of my front trac bar and have Disconnects on there...
But I usually leave them off.
One time when I was driving in extremely windy weather did i stop and take the time to put them back on. Then left them off after to removed them the next time.
Would have done the rear one, but I forgot to when I put my lift on and I cant get to the torx head very easily, but when I have the time and get to working on it again... Its gone!
james
My 4.0 is in.... it runs, now let's see if we can get it on the road!!
leftovers (from the 4.0 swap) for sale.
sauce90yj is offline
post #33 of 1435 Old 04-03-2007, 09:12 PM
jazzplr
Rear tracbar too short?
It looks like I need to remove my rear tracbar after installing my Skyjacker 2.5 lift. I took it in to get an alignment today and the tech showed me how the tracbar was pushing the rear axle out to the right causing all sorts of problems. I also need to install shims under the rear springs due to driveshaft vibrations. What size torx bit do I need to remove the tracbar and what would be a good angle to start with for shims?
Hero's aren't born, they're cornered
jazzplr is offline
post #34 of 1435 Old 04-03-2007, 09:25 PM
kbazurpe
kbazurpe's Avatar
1973 CJ5
Should be a T55 torx bit. No idea on the shims
kbazurpe is offline
post #35 of 1435 Old 04-03-2007, 09:26 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
IIRC, the tracbar torx bit size is a T55.
As far as the shim degree goes, it depends on if you run a tcase drop too. As a WAG, a 4* shim might do the trick but that's just a WAG.
Joe Dillard is offline
post #36 of 1435 Old 04-03-2007, 09:45 PM
timatoe
timatoe's Avatar
Joe using terms like WAG I'm suprised you didn't say to just move it an RCH.
I think the sawzall will also work on getting that track bar off.
timatoe is offline
post #37 of 1435 Old 04-03-2007, 09:57 PM
72cj5er
72cj5er's Avatar
1972 CJ5
Mine has extensions attached to the axle, about a 3" steel part that raises the lower bar mount, thing get loose all the time. Ill try and get a pic tommorow for clarity.
72 CJ5 Renegade
86 MJ Pickup W/Tilt bed
94 YJ Wrangler
04 LJ Unlimited Wrangler
never far from a good trail
Growing old is mandatory; growing up is optional!!
72cj5er is offline
post #38 of 1435 Old 04-03-2007, 10:14 PM
jazzplr
I haven't dropped the tcase. The Skyjacker instructions mention a shim. I just bought the springs off someone though and didn't know about a shim.
jazzplr is offline
post #39 of 1435 Old 04-04-2007, 06:28 AM
jazzplr
Nobody has installed shims on a 2.5" lift?
jazzplr is offline
post #40 of 1435 Old 04-04-2007, 07:09 AM
chupacabrah
chupacabrah's Avatar
just get a tcase drop, it'd be cheap and easy.
lose some clearance in the middle though.
-Jon
'93 YJ with 1 ton SOA in progress (slowly).
chupacabrah is offline
post #41 of 1435 Old 04-04-2007, 07:30 AM
saharajeepman
i had to use a sawzall to get the top mount of the track bar off. i just cut the back nut off.
'89 Sahara 4.2 258 Upstate, NY
31x10.5 BFG All Terrain, 470 cfm Holley Off-Road Avenger, Nutter Bypass,
RE 2.5, Currie Shackles front and boomerang rear
TJ front driveshaft, SYE, Tom Woods rear driveshaft, Posi-lok, AX-15 swap.
saharajeepman is offline
post #42 of 1435 Old 04-05-2007, 09:12 PM
jazzplr
OK, installed 4 degree shims today and driveline vibe is much better. I also took off the rear track bar and can't believe how much smoother the ride is now! How much thread would I have on the transfer case bolts to add some washers to lower it a half inch or so? Would I need to replace the bolts with longer ones?
jazzplr is offline
post #43 of 1435 Old 04-05-2007, 09:16 PM
sticksnstonesru
Why only four degrees if you needed more. I'm going to assume you're adding washers the TC to get more of the vibe settled, right?
If you do change the bolts (which I don't think you'll need to) go with grade 8's...better safe than sorry.
1993 YJ | 2.5L 4 banger | 3.5" Superlift | 1" BL | 4.88's | 33" BFG's |
2007 Toyota Tundra Crew-max | 4x2 | 5.7L | Truxedo Tonneau | 20"'s | Leather | Fully debadged
1999 XJ | stock | 4.0
sticksnstonesru is offline
post #44 of 1435 Old 04-05-2007, 09:20 PM
jazzplr
Well, four was all I could get my hands on and it's my DD so I was in a bind to get some relief fast. Yes, I'm trying to get some of the vibe settled and was hoping just some washers would get me where I needed to be. I am planning on starting at 1/4" and going from there.
jazzplr is offline
post #45 of 1435 Old 04-05-2007, 10:46 PM
95builtjeep
if you remove that trackbar the rear will flex like it should. just an idea. i haven't had trackbars on my jeep in 2 years, and i can't even tell much of a difference, especially with sturdier heavier duty springs like you're running.
95builtjeep is offline
bars , front track bar , jeep , remove , steering , sway bar , trac bar , trac-bar , track , track bar , trackbar , YJ
my track bar and sway bar removal w/pics YJ89jeepTX YJ Wrangler Technical Forum 1 03-27-2010 08:56 PM
Sway bar/Track removal...Right for me? SkullTripper YJ Wrangler Technical Forum 2 02-20-2010 10:40 AM
Sway and Track bar removal question - jeepsurf YJ Wrangler Technical Forum 7 01-14-2009 10:16 PM
sway bar and track bar removal petersyj95 YJ Wrangler Technical Forum 3 01-14-2009 07:41 PM
Track Bar and Sway bar removal Tim3852 YJ Wrangler Technical Forum 4 06-13-2006 02:47 PM
