Front track/sway bar removal pics(repetitive/redundant questions merged here as well) - Page 11 - JeepForum.com
 13Likes
post #151 of 1435 Old 08-01-2010, 10:38 AM
ThomasYJ
Originally Posted by ZeroGravity View Post
This thread is for information purposes and if you choose to remove your sway bars, it's your responsibility what happens to the rig and your health. If you think it's un safe, then make your own thread and see who gives a ****.
I don't care about your fancy disconnects or your telescoping track bars. If I wanted to discuss that I would make a thread about telescoping track bars and sway bar disconnects.
I put a lot of time into publishing this write up. Don't come into my thread and try and tell me that I'm stupid or that I do anything without consideration.
THAT'S what I like to call, a Head Shot response!!
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #152 of 1435 Old 08-01-2010, 03:11 PM
Karma
opp's, wrong thread.
Karma is offline
post #153 of 1435 Old 08-01-2010, 05:10 PM
LeJerk
2009 JK Wrangler
I took my sway bar off the other day, and I would suggest just using a wrench before taking a grinder to the bolts. My bolts and nuts came loose with not too much drama. This way, if you don't like the ride, you can just put it back together without having to hunt down new hardware that you just destroyed.
LeJerk is offline
post #154 of 1435 Old 08-01-2010, 06:36 PM
ZeroGravity
If you can get your bolts out without cutting them I definitely suggest that as a first option
By the way, who put this in general?
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #155 of 1435 Old 10-14-2010, 06:50 PM
stm144
Yj front track bar bolt size help
My 94 yj has a nice turn to the right every once in awhile. When I added my lift I had to replace the trackbar due to the bolt being pretty much plastic welded to the bushing. I replaced the whole trackbar but icouldnt get my hands on the right size bolt. Since then I forgot where I wrote down the correct bolt sizes for the front track bar. I am pretty sure that it was a 12mm fine thread. Can anyone confirm the size and give me the right length I would greatly appreciate it. I've been looking all over this site and the Internet and can't find a damn thing. Any help would be greatly appreciated.
Thanks
stm144 is offline
post #156 of 1435 Old 10-14-2010, 11:00 PM
MJMPC
You are gonna hear it so let me be first dicth the trackbars ft and rear both.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #157 of 1435 Old 10-14-2010, 11:23 PM
GottaYJ
^x2
GottaYJ is offline
post #158 of 1435 Old 10-15-2010, 08:46 AM
stm144
Thats fine for trail riding however my jeep gets alot of use in the winter when the weather is questionable and id rather not have to jerk the wheel every so often to keep the thing straight.
In the case of ditching the track bars, if anyone ditches theirs can they measure the bolts for me first before they throw everything away.
Anybody have any sizes and not suggestions to ditch it?
stm144 is offline
post #159 of 1435 Old 10-15-2010, 09:05 AM
superj
probably not. everyone ditches it because it works in a different plane then the leaf springs so they fight each other and cause a very rough ride.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #160 of 1435 Old 10-15-2010, 09:49 AM
SpideYJeep
stm144 - Depending on other projects and whether or not mine will come off easily, I'll probably be removing my track bars this weekend. If I like the ride better, I'll send you my bolts if you cover shipping.
Or you can go to a pick-a-part/pick'n'pull and get them.
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
post #161 of 1435 Old 10-15-2010, 10:51 AM
fwb35
So even for 90% street use and stock height I should get rid of the track bars front and rear????
fwb35 is offline
post #162 of 1435 Old 10-15-2010, 10:58 AM
superj
i use mine 100 percent street and i tossed them and mine is totally stock
superj is offline
post #163 of 1435 Old 10-15-2010, 11:06 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Track bars are worthless on a leaf sprung vehicle, period. What you should keep with a stock height suspension is the sway bar. This is becuase the springs are softer and worn out from years of use, you'll have more body roll than with new, stiffer lift springs.
If you're having driveability issues, there is something else wrong besides the track bar, because CJ's don't even have track bars, and 95% of us YJ's on here don't either.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #164 of 1435 Old 10-15-2010, 11:18 AM
SloppyJoseph
Track bars aren't going to cause your vehicle to drift off. You have other problems. I'd start by checking your tie rod ends.
First Jeep
SkyJacker 4" lift, 32" BFG M/T's, Smittybilt Rocker guards, XRC Front bumper, XRC 8 Winch and bikini top, KC Fogs and Warn Driving lights, M.O.R.E. 5/8" Boom Shackles, Rugged Ridge HD Steering, Rhino Lined, SkyJacker Hydro Shocks and Steering Stablizer, Bestop Seats, MCE Front Fenders
SloppyJoseph is offline
post #165 of 1435 Old 10-15-2010, 11:24 AM
muddy93
1987 FSJ Wagoneer
As others have said, the track bars are NOT needed.
I've said this before, The only way that you will notice any ill effects from remvoing the track bars, is if the rest of your suspension is worn out.
Leaf spring suspensions do not need a track bar, the leaf springs locate the axle, as well as support the weight. The problems arise when the spring and shackle bushings are worn(at which point, they should be replaced, regardless of weather you're running a track bar or not.). With worn bushings, the springs can then move side to side (pivot around the bushings), which will let the axle move side to side, and make the steering feel loose or unresponsive.
For example, I'm running a 3" suspension lift, and removed both track bars, as well as the sway bar, about 5 years ago, and aside from a better ride on the road, and better flex off road, there was no change in the way it drives.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
bars , front track bar , jeep , remove , steering , sway bar , trac bar , trac-bar , track , track bar , trackbar , YJ
my track bar and sway bar removal w/pics YJ89jeepTX YJ Wrangler Technical Forum 1 03-27-2010 07:56 PM
Sway bar/Track removal...Right for me? SkullTripper YJ Wrangler Technical Forum 2 02-20-2010 09:40 AM
Sway and Track bar removal question - jeepsurf YJ Wrangler Technical Forum 7 01-14-2009 09:16 PM
sway bar and track bar removal petersyj95 YJ Wrangler Technical Forum 3 01-14-2009 06:41 PM
Track Bar and Sway bar removal Tim3852 YJ Wrangler Technical Forum 4 06-13-2006 01:47 PM
