Front track/sway bar removal pics(repetitive/redundant questions merged here as well) - JeepForum.com
 13Likes
post #1 of 1435 Old 03-09-2004, 02:43 PM Thread Starter
tomwbates
2009 JK Wrangler
No way, I removed my front and rear. Only difference i could tell was that it rode better!
'09 JK Unlimited Red Rock
tomwbates is offline
post #2 of 1435 Old 03-09-2004, 02:56 PM
bamakrw
Originally Posted by catfisch
Just installed a 3'' RC Lift and caught hell getting the top bolt out of the rear track bar (so i just let it for the time being).. did yall bother hooking yours back up? -Cat
It took me a while but I eventually got it out and hooked it back up with the relocation bracket. I took my front one off but only because I couldn't figure out how to mount the relocation bracket.
bamakrw is offline
post #3 of 1435 Old 03-09-2004, 03:06 PM
catfisch
catfisch's Avatar
I'm not really having any problems w/ it .. except my rear drums are a little out of adjustment so when i really have to get into the brakes the *** end wants to float all over the place.. feels like i'm pulling a really heavy trailer. So i think one drum is engaging harder them the over and it's making my rearend shift a little as the shackles and springs flex. Of course it snaps right back into aliginment soon as i stop. -Cat
"The Jeep is the only real American sports car."
-Enzo Ferrari
-95 YJ
-4.0L High Output
-PowerAid Spacer
-Herculined Tub
-Brand New- AX15
-3'' RoughCountry Sus. Lift
-1.5'' lift-Conferr Shackles
-1'' Body lift
-No rear trackbar
-33x12.50 SuperSport H/T's
-10'' OutlawII Rims
-CB etc
catfisch is offline
post #4 of 1435 Old 03-09-2004, 03:29 PM
pdw
pdw's Avatar
The instructions for the Rubicon Express 4.5" lift tell you to get rid of the rear trac bar, but to keep the front trac bar.
I guess that you can run without the front trac bar on the street, but is that such a good idea? Doesn't the front trac bar help to keep your steering consistant? Especially under braking conditions or emergency manuvers?
pdw is offline
post #5 of 1435 Old 03-09-2004, 03:48 PM
bamakrw
Just installed a 3'' RC Lift and caught hell getting the top bolt out of the rear track bar (so i just left it for the time being).. did yall bother hooking yours back up? -Cat
Did you hook your front track bar up using the relocation bracket provided? From the instructions that were provided in my kit, it
looked as it (the bracket) should have been mounted on the passenger side and not the driver side where it is supposed to be on my 90 model.
bamakrw is offline
post #6 of 1435 Old 08-30-2006, 09:14 PM
iwishihad1
swaybar+tracbar gone = bad road manners
hey everybody
my buddies got a 92 yj with 1.5 inch suspension lift, 1 inch body and 32 inch BFG muds. he does great in the mud, but anything that requires any flex at all, hes not going anywhere. are there swaybars front and rear, and tracbars front and rear that can be removed to help his flex.
and if we do how bad will it be on the road
thanks
iwishihad1 is offline
post #7 of 1435 Old 08-30-2006, 09:36 PM
COSourdough
There are about a gazillion threads on this subject; general consensus seems to be: Get rid of the rear track bar, take off the front trackbar and sway bar and try it out, sensibly, see how you like it. If you're not happy with the body roll on the road, get diconnects for the swaybar. Personally, I got rid of swaybar and both trackbars and don't notice any negative effects on the road. Get a lot more flex and even a bit smoother ride on the road.
COSourdough is offline
post #8 of 1435 Old 08-30-2006, 09:40 PM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
I removed my front and rear track bar with no ill effects that I can see. But I do not think it is safe to go without the sway bar, although some guys think it is OK. Get a set of disconnects for the sway bar. You will be glad you did if you ever get into an emergency maneuver at high spped.
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
post #9 of 1435 Old 08-30-2006, 10:03 PM
z71offroader
z71offroader's Avatar
trac bars wont affect ur handling but ur sway bar in the front will, id suggest just like above....remove all trac bars and get some disconnects.
93 YJ- SOA, R.E 1.5" Leafs, Custom paint, 35x16 Boggers,15x10 97 series rockcrawlers. Diamond plated interior and exterior, Tera SYE/CV DS, Herculined Tub, Bestop, Warn Bumpers w/ 9.5ti, 8.8" rear, D30 front, both ARB's with 4:88's, Super 88, Posi-Lok, Alpine Stereo, Tuffy Security, Hella Fogs, ProComp Spots, and much more.
07 2500HD D-Max CC LB Black Ranchhand Bumpers, MBRP 5" Straight Piped Exhaust, Edge Evo, N-fabs, 305/65/18 BFGs on Black Motos, much more soon to come!
(Sold)03 Z71- 33x12 BFG Muds, American Racing Victor Teflons, K&N intake, Gibson Exhaust, Ranchand bumpers, Hypertech programmed, Hella Spots, 12" JL sub, and much more.
z71offroader is offline
post #10 of 1435 Old 08-30-2006, 10:08 PM
bobbert350
bobbert350's Avatar
track bar not a bad idea to remove..but the sway bar u will get a ton of body roll..u can try to take them both off its not too hard..i would take the track bar off then drive it a bit...then if happy but want to take the sway bar off take that off and see how u like it cauz u can alway put it back on
bobbert350 is offline
post #11 of 1435 Old 08-30-2006, 10:41 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
No problems for me towing a trailer. My Jeep is on 38" tires - no sway bars or trackbars on my Jeep for the last 4 years.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #12 of 1435 Old 08-30-2006, 11:03 PM
bowenjeep
I took the trac-bars and sway bars off when i had my 28' tires and it was somthing to get used to but bearable.
I just put on some 31's and now you can say goodbye if you have to make any kind of emergancy manuver. Looking into disconnects myself.
bowenjeep is offline
post #13 of 1435 Old 08-31-2006, 06:55 AM
COSourdough
I've got 31s, and 3" lift; I don't notice any body roll, even when swerving at higher speeds. I guess it all depends on the springs. I'm not throwing the swaybar away yet, because I'm eventually gonna replace my Rough Country crap with better springs, and I might need to put the bar back on.
post #14 of 1435 Old 08-31-2006, 08:54 PM
iwishihad1
ok..thanks everybody
hes coming over sunday for removal of his front and rear tracbar, and swaybars. yjs have a swaybar in the rear also correct.
hopefully our wheelin trip monday, hell be much happier with his jeep. if it could flex he could definately go some places. hes a pretty decent driver, but with a suspension, where axles might as well be welded to the frame, and open differentials. anytime something off camber comes into play hes not moving
so thanks for the help
post #15 of 1435 Old 08-31-2006, 09:10 PM
phittie1100
No rear sway bars on a YJ, just on the front. Trac bars at both ends. I don't run w/trac bars. I don't mind my sway bar disconnected around town, but it's a little dicey on the freeway.
Paul - 2005 Wrangler Unlimited
KD8PAV
phittie1100 is offline
bars , front track bar , jeep , remove , steering , sway bar , trac bar , trac-bar , track , track bar , trackbar , YJ
my track bar and sway bar removal w/pics YJ89jeepTX YJ Wrangler Technical Forum 1 03-27-2010 08:56 PM
Sway bar/Track removal...Right for me? SkullTripper YJ Wrangler Technical Forum 2 02-20-2010 10:40 AM
Sway and Track bar removal question - jeepsurf YJ Wrangler Technical Forum 7 01-14-2009 10:16 PM
sway bar and track bar removal petersyj95 YJ Wrangler Technical Forum 3 01-14-2009 07:41 PM
Track Bar and Sway bar removal Tim3852 YJ Wrangler Technical Forum 4 06-13-2006 02:47 PM
