Front track bar yes yet again even though its been beat to death tell me why to keep - JeepForum.com
post #1 of 33 Old 02-24-2009, 12:46 AM Thread Starter
Goobersbro
Okay i know i have asked and i have done the search thing but i just want some extra reasurance. I took the rear track bar off and forgot about it but i have been told by some front end shops to keep the front track bar on. So i have looked around and found some adjustables. I really like the Jks adjustable track bar. So my question is why should i get rid of the front track bar. Why should i not. What other leaf sprung vehicles have track bars? and can you make a quick disco system for you track bar??? I just want to make sure before i spend 170 bucks on an adjustable track bar and i want some good reasons to explain to my dad and the guy at the front end shop as to why I dont need or I need a good reason to tell my Grandma why i want her to buy me an adjustable track bar
My marshmallow build
Goobersbro is offline
post #2 of 33 Old 02-24-2009, 04:54 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
It sounds like you need to just remove it and take it for a drive to decide yes or no.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 33 Old 02-24-2009, 06:42 AM
champelite210
Remove it. As long as your bearings, tie rods and ball joints are good then it drives the same. If it feels extra loose then you may need to replace some other parts. Don't get the JKS I've read that it contacts the diff cover on some models.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #4 of 33 Old 02-24-2009, 07:42 AM
lonestar_yj
i dont know if anyone does these but you could get a hitch pin the same size as your bolt and make a quick disco.
93 wrangler sahara, 4" lift, 1" shackles, 33x12.5 maxis buckshots on crager rims, hm front,back bumper,towbar, hand throttle
lonestar_yj is offline
post #5 of 33 Old 02-24-2009, 08:23 AM
themonkeyman
1987 YJ Wrangler
If you wanted reassurance, why not use the search and wade through the trillions of threads on this subject....
themonkeyman is offline
post #6 of 33 Old 02-24-2009, 08:28 AM
Jeeples
Jeeples's Avatar
Ditch the track bar and get some quick disconnects for your front sway bar. The leaf springs will provide plenty of lateral support to keep the front axle centered and the sway bar will help to keep body roll in check, which is especially important if you have a higher center of gravity.
I ran fully disconnected when my YJ was on stock leaf springs and didn't have any issues at all, however once I put my RE 2.5" lift on there was a bit too much body roll for my liking so I re-installed the front sway bar
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #7 of 33 Old 02-24-2009, 08:32 AM
Levinz11
I had the same aprehensions. But after removing mine had zero ill effects. She drives just fine and quite a bit smoother over sharp edged bumps and freeway joints.
PLEASE DEPOSIT $.75
Levinz11 is offline
post #8 of 33 Old 02-24-2009, 09:52 AM
Cross
The only way to know is remove it yourself and try it. Some people freak out and think the Jeep is going to kill them, others do not even know its gone.
continue on.
Cross is offline
post #9 of 33 Old 02-24-2009, 09:58 AM
texas_yj
not to beat a dead horse ^^^^, but I had serious reservations about removing them too, but just tried it and couldn't tell it was gone other than it rode better, now I'm running 33"s and 4.5" lift with no regret for the missing parts
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt.
2) (Sold) 99 TJ, mustang 5.0 GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT, superlift 6" long arm, D30/44 w/ ARBs & yukons, customized warn bumpers, custom sliders, 12K winch w/ synthetic rope, custom paint
3) 2007 JKU being built now
texas_yj is offline
post #10 of 33 Old 02-24-2009, 10:27 AM
PeteYJTJ
I took mine off, but the one thing I tell people if they want to remove it, is this: Keep an eye on your front shackle brackets that are welded to the frame. Look out for cracks. Without the trac bar, all of the lateral force of the axle is transmitted through your shackle brackets. Also, longer shackles magnify this force -- the force trying to peel off your shackle brackets.
I'm not saying it's a bad idea to take it off, I'm just saying that when you remove parts from the Jeep, you need to think about where that force goes, that used to be taken by the trac bar.
Good luck
Pete
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
post #11 of 33 Old 02-24-2009, 10:39 AM
USMC_JeepGuy
Lose it! It was a bad answer to the "rollover scare" of the late eighties early nineties. Useless to a leaf sprung vehicle that's axle is already located in 3 dimensions.
BTW, I took mine off and the sway bar, drive 180 miles on the fwy and can't tell it's gone but for the better ride.
USMC_JeepGuy is offline
post #12 of 33 Old 02-24-2009, 10:59 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
continue on.
X 1,000,000
For God's sakes, just ditch the freakin' thing already......
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #13 of 33 Old 02-24-2009, 11:23 AM
texas_yj
You sound a little agrivated "mean Max", looking to justify your name maybe just messin with man . . . . .
texas_yj is offline
post #14 of 33 Old 02-24-2009, 11:52 AM Thread Starter
Goobersbro
lol mean max i know i know this has been beaten into the ground im just super cautious on this front one. I do have to replace my ball joints, tie rods, steering Column and i need to buy a steering dampener since the one on the jeep is still the stock one and has zero oil left in it thanks to the PO!!. I did notice when i got under it and turned the wheels that the bracket they sold with the procomp lift to raise up the track bar moves quite a bit when i turn right or left is that normal??? the only reason i ask is why is my axle moving from side to side like a half an inch if the track bar is still implace. Isnt the purpose of the track bar to keep the axle centered under the vehicle. And also say im on the high way and have to swerve fast will I experience over steer with it off. Like from the axle moving and then turning???
post #15 of 33 Old 02-24-2009, 12:34 PM
JaikYJ
You dont need your track bars, CJ's never ran them and YJ's have wider beefier springs. I think the dealership had to put them on to meet stricter safety regulations. But most jeepers find that all they do is limit flex. If you do have a lift I would recomend keeping your sway bar and making some disco's.
87 YJ(sold), 97 TJ(sold), 99 TJ(daily)
03 R1 (fun)68 Mustang Coupe(summer)
67 Fastback(resto)
JaikYJ is offline
Front Track Bar Help (Death Wobble) rbwamsley TJ Wrangler Technical Forum 59 09-12-2011 07:28 PM
this has probley been beat to death. rusteze Wrangler General Discussion 6 05-15-2009 04:59 PM
JKS front track bar going looooooose so I get DEATH WOBBLE! humbertotrevino TJ Wrangler Technical Forum 4 11-25-2008 08:27 AM
beat to death blueandyellowed TJ Wrangler Technical Forum 6 05-22-2008 05:45 AM
Beat to death I'm sure..... Dudewayne TJ Wrangler Technical Forum 3 06-24-2006 07:16 PM
