front tire smoking and wheel steaming hot - JeepForum.com
post #1 of 25 Old 12-06-2007, 11:15 PM Thread Starter
renegade10s
So i hit a slight bumb on my way way home tonight from a indoor soccer game. i hit the bumb with my front right tire and it didnt seem like to big of a problem at that moment.
Later once i had dropped my friend off i noticed that the jeep was pulling to the right a little bit and was dumb founded why.
I later (still on way home) was going down a slight hill and decided to put the car into neutral and see if that had any effect on it. well it did, alot. The car was slowing down as i was trying to coast down a hill? it was slowing down at a rate of me slightly putting my foot on the brake. weird?
i checked and double checked 4wd and parking brakes and everything and when i got home i had smoke coming from my right tire!!!! ahhh
its dark out and couldnt really look at it well so ill take it to my grandpa (mechanic) and see what he thinks is up.
One last thing. i think there must be alot of friction going on in my wheel well cause i touched my wheel and almost burnt my hand it was steaming hot...
yaaaa.
not good.
Any ideas or comments welcome on what u may think is my problem is greatly appriciated!!
free water!
renegade10s is offline
post #2 of 25 Old 12-06-2007, 11:52 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Yea it sounds like your calipers are locked up. Don't drive around like this, your heated up brake will cause the brake fluid to boil making bubbles in your brake line. Then your brakes may stop working. Get it fixed right away.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
post #3 of 25 Old 12-06-2007, 11:56 PM Thread Starter
renegade10s
thanks a bunch! where is a good place to get some calipers? and whats usual cost?
free water!
post #4 of 25 Old 12-07-2007, 04:26 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Your looking at $40-$50 per side plus there will prolly be a $40-$50 Core charge. You get that back when your done Or take the busted one with you when you get the new part.
I like Napa parts for brakes, but advance auto is also good.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 25 Old 12-07-2007, 06:28 AM
Cobra Jeep
Yes, that is defintaely a caliper locked up. Like said, dont drive it. When you get calipers, go ahead and get both sides. If one locked up, the other is probably not far behind it. Also get new brake pads. Lots of parts stores sell calipers with pads already on them, called "loaded" calipers. Also get new rotors. With the one side being cooked, it is probably warped and heat damaged now. And its kinda the calipers, might as well replace both sides.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #6 of 25 Old 12-07-2007, 06:43 AM
red87yj
red87yj's Avatar
1987 YJ Wrangler
X2 on the whole front end break job. Especially if it was hot enough to get the tire that hot. While you are in there check the bearings too (easier to do while you are aleasy in there I don't know if heat would do anything to them but I would judt go over everything) break line too maybe?
Later
Zach
1993 YJ with a 4.0 & TF 999 & Np 231 (All to change soon!)
SOLD!!!87 Red YJ with 95 4.0 & NV 3550 & Dana 300 Flipped
3.5 BDS Lift
red87yj is offline
post #7 of 25 Old 12-07-2007, 07:05 AM
dell2028
dell2028's Avatar
Calipers are a good place to start. Check the pads and rotors while your down there and have everything apart. Remember to bleed the brakes once your done. Might want a buddy when you do it. I think last time I did brakes calipers were 30 per side once you turn your old one in. Pads are 30 for both sides and rotors are about 30 per side. (Advance Auto)
95 YJ, D30/8.8 w/ 4.88s, SOA, 35x14.50x16.5 Pit Bull Mud Dawgs, 101" Wheelbase, Custom Front Bumper, Winch, Custom Rear Tow Points, Traction Bar, Aussie Locker in front, 20 Gal. Gas Tank modification, Hurculiner Tub, Custom Rear Bumper, SYE and CV shaft, BTF Cross-over Steering, RCI 2191 fuel cell, BTF Rockers, RE 1.5" SOA springs up front and XJ springs in the rear
Down the line a bit...engine swap, the list goes on.
dell2028 is offline
post #8 of 25 Old 12-07-2007, 11:01 AM
Ryanpowell167
Last time i checked for calipers on my 92 they were 16 bucks each at oreillys
Black 1992 wrangler, 40" creepy crawlers, d60/14b 350tbi/700r4/np205, spring over on 4" springs.
2011 Ford F-150 Raptor, whipple supercharged...
Ryanpowell167 is offline
post #9 of 25 Old 12-07-2007, 11:22 AM
jeepwrnglr92
2015 JK Wrangler
i got mine at pepboys or bennet for $20 a piece.
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline
post #10 of 25 Old 12-07-2007, 11:38 AM
bobbert350
bobbert350's Avatar
you can get a set of pretty good remanufactred calipers form advanced i got mine for 20 bucks after the core for each side
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
post #11 of 25 Old 12-07-2007, 12:44 PM
bryris
This doesn't mean you necessarily need new calipers. This happened to me a few months ago and I drove home - only about 2 miles from where it happened. I unscrewed the wheel, pulled the caliper and doused it with hi temp disc brake grease. I replaced and lubed the caliper pins, slapped new pads on there while I was at it, and its been humming along just great since.
I did the same thing to the non stuck side to just for symmetry.
Try it.
bryris is offline
post #12 of 25 Old 12-07-2007, 01:03 PM
martells2
I'd be willing to bet you're going to need new unit bearings
Help Zach Beat Cancer
martells2 is offline
post #13 of 25 Old 12-07-2007, 01:37 PM
bryris
He said "unit".
bryris is offline
post #14 of 25 Old 12-07-2007, 03:57 PM Thread Starter
renegade10s
ok so i took my tire off and took out the piston and it was kinda locked into the position. so i took it off and lightly sanded the top of it to get some gunk off and re oiled it along with new brake fluid and cleaned the brake pads off. worked great and no problems so far...
free water!
post #15 of 25 Old 12-07-2007, 04:47 PM
builder
I would bet its the soft brake line. The steal on the inside gets crappy and calapsis. when the fluid gets to hot it cant back out of the caliper. I had this happen to me and its a commen problem.
95 YJ
builder is offline
Passanger Front Brake Smoking RedlineRyan YJ Wrangler Technical Forum 15 03-04-2009 07:03 AM
Front of my hood steaming? chipda2nd TJ Wrangler Technical Forum 23 05-24-2008 03:55 AM
Weird Vibration Coming from Front Left Tire/Wheel Catrone TJ Wrangler Technical Forum 3 03-03-2008 08:58 PM
Right front wheel/tire wobble? skeletor YJ Wrangler Technical Forum 10 11-09-2005 10:31 AM
HELP! Front Pass Brake Smoking jeepnewbe YJ Wrangler Technical Forum 9 10-28-2003 10:49 AM
