front spring issues - JeepForum.com
post #1 of 31 Old 09-01-2014, 09:25 AM Thread Starter
Gungnir
front spring issues
hey all, i got a 90 yj with SOA, 8.8, running 35's and my front springs keep turning them self into an S shape. Im on my 4th set of springs in 3 months, this time im useing hd springs, they have been on for about 2 weeks and im starting to feel it happen again. what could be causing this.
the first 3 sets of springs were stock and no idea of age or condition, the hd springs were only a year old when i got em and half that year was spent sitting on a shelf in a garage.
the check engine light and coolant sensor bad warning on my ZJ arnt on. I think my jeep might be broken :(
Gungnir is offline
post #2 of 31 Old 09-01-2014, 09:48 AM
1tuffyj
What kind of power are you running? How hard do you wheel? Is it shackle reversed?
the pressure makes us stronger, the struggle makes us hunger, the hard lesssons make the difference, and the difference makes it worth it.
1tuffyj is offline
post #3 of 31 Old 09-01-2014, 09:52 AM Thread Starter
Gungnir
I got a 4 banger, I wouldnt consider my wheeling to hard not stock friedly but i dont push it to its limits, and the shackles arnt reversed.
Gungnir is offline
post #4 of 31 Old 09-01-2014, 11:50 AM
89yjislanderr
did you do the soa or did a shop do it? that'd be the first thing i'd visit.
89yjislanderr is offline
post #5 of 31 Old 09-01-2014, 09:33 PM
Yj350tbi
Longer spring perch might help. And a traction bar. Maybe to long of shackles? Is this a bolt on spring over?
Yj350tbi is offline
post #6 of 31 Old 09-01-2014, 09:43 PM
mike134
can you show a picture of your spring set up? maybe with the wheel off?
mike134 is offline
post #7 of 31 Old 09-02-2014, 10:52 AM
timatoe
timatoe's Avatar
Is it possible you're inverting the shackle? Like this......
If so, a set of boomerang shackles will likely stop that.
timatoe is offline
post #8 of 31 Old 09-05-2014, 02:26 PM Thread Starter
Gungnir
My shckles are good, my front srpings wrap every time I put it in 4 wheel drive
This didnt always happen, my cad went so I did the diy posi lock, then the springs. Put new springs on went out wheeling diy posi broke, I locked the collar so I could get out of the bush and my new used springs wrapped, picked up s8me hd springs and installed the posi loc from rugged ridge, put it in 4xr turned on pavment and they wrapped again.
Gungnir is offline
post #9 of 31 Old 09-06-2014, 05:39 AM
Mike Romain
Do you by any chance have mismatched gear ratios? I mean, running in 4x4 on pavement is just plain asking for something to explode, usually a u-joint, but I have seen a t-case blown in half on a Cherokee from this. Axle wrap more implies gear ratios in my mind.
Mike
Mike Romain is offline
post #10 of 31 Old 09-06-2014, 07:03 AM Thread Starter
Gungnir
Ill have to check that out, I know my 8.8 has 4 10 gears I just assumed thats whats in the front.
Gungnir is offline
post #11 of 31 Old 09-06-2014, 07:11 AM
Steve707
Wouldn't that destroy his tcase?
Do you have a 4 or 6 cylinder engine?
Steve707 is offline
post #12 of 31 Old 09-06-2014, 07:37 AM Thread Starter
Gungnir
I got a 4 cyl.
Gungnir is offline
post #13 of 31 Old 09-06-2014, 07:39 AM
Steve707
Your front axle should have the same gear ratio then. And I'm pretty sure you would have broken something if they were different ratios unless you happened to have the right tire size difference for the gear difference.
Steve707 is offline
post #14 of 31 Old 09-06-2014, 08:09 AM Thread Starter
Gungnir
I dont know if this helps but I went to disengage my 4 wheel drive and it wouldnt disengage, I popped the back off the cad and couldnt slide the colar over. I put it in natural aand went to push it and it wouldnt go anywhere. It felt like it was still in gear. I jacked up the front end and the driver tire had built up energy in or somthing because it really spun soon as the pressure was taken off it.
Gungnir is offline
post #15 of 31 Old 09-06-2014, 08:22 AM
Mike Romain
Yes, it does this when driving on pavement in 4x4 just before a u-joint or t-case explodes from the stress built up. When you turn, the front wheels travel farther than the back ones so one tire has to scuff the ground to compensate when the front and back driveshafts are locked into 4x4. That is why you are only supposed to use 4x4 on dirt or snow.
Sometimes driving in reverse and turning can unwind things so it will release, but sometimes you have to jack up a wheel.
If your gear ratios are off, this is way worse. Are you sure the 8.8 is 4.10? That makes for a slight mis match because the fronts are 4.11 if I remember right. Not enough to wrap things, but sure enough to make it worse on pavement .
Mike
